Stuck carburetor butterflies
Home  \  Repairs & Maintenance  \  Stuck carburetor butterflies
Hi, I'm rebuilding a four barrel Carter ThermoQuad carburetor,(for a 340 chrysler engine) and when I got it, it was pretty much all seized up. I soaked it in a bucket of carb cleaner for about three days and sprayed penetrating lubricant like crazy and got it all apart. However the butterflies on it are still stuck, and it seems like I've tried everything to get them loose but they still refuse to budge.:banghead: Anyone have an idea(s) on how to loosen them? Any help would be greatly appreciated.
posted by  Pinstriper38
you could try a little heat(just enough to warm it dont want to melt or warp the base) where the shaft goes through the carb body and cooling it back down with a non flammable penetrating oil the heat will expand the carb body and shaft allowing the pentrating oil in as it cools work it little by little each time it will loosen up
uhh..i did that and as i was tapping the shaft out of the body, the *#@$in thing cracked right along the bushings. :cussing: i think i may have heated it too much. but, i paid $10 for the thing at a swap meet, so no big loss.
that sucks did you use an oxy/acet or propane torch
no, that'd be overkill. i used a little propane torch.
like one thats a little bigger than a bic lighter
thats odd must have been the bushing expanded faster than the carb
naw...it was one of those Bernz-o-Matic ones that are a little bigger than a spray paint can. and yes, it is wierd, the carb comes apart at three places, the throttle body is about 3/4" and it just split in half right along the bushings
any chance of saving it with some 2 part metal epoxy you can get at most parts stores. fill in the crack file it down and smooth out with some sandpaper
yeah, i was thinking about doing that
that stuff save's a lot of parts found some other stuff called form-a-thread worked great on the aluminum outboard block i striped a bolt in for the thermostat mixed the paste then coated the threads with the release agent put it together still holding a year later
cool, one more question, do any of you know how to get a broken carb adjusting screw out?
set of ez-outs from sears or parts store
i guess it broke in flush or deeper and you can't use vise-grips
nope, its in there flush
Man, it sounds like that carb was under water. :laughing:
posted by  srober32
hahah, it was waayyy under water :orglaugh: almost literally lol
You might want to see if you can get another carb and try boiling the base plate in water, sometimes that works to loosen stuff up and it also does a pretty good job of cleaning out the vacuum ports.
posted by  srober32
