I NEED HELP FINDING THE SET TIMING CONNECTOR ON A 94 gmc YUKON 5.7 350 TBI
Home  \  Repairs & Maintenance  \  I NEED HELP FINDING THE SET TIMING CONNECTOR ON A 94 gmc YUKON 5.7 350 TBI
I have a 1994 GMC Yukon. I need to know where the set timing connector is located. I hear it's a tan color or something to that effect. Thanks
posted by  coyote_pass
under the hood right side fire wall the fuse panel relay cover right side of fuse/relay center looking at it single wire round connecter
if its not there then check near or in the harness to the distributor
if you dont find it on the firewall, check under the passenger side of the dash, just in front of the hvac case for a single brown wire with a square connector.
posted by  DFgerbil
