1994 Ford F-150 Shift and ABS problem
Home  \  Repairs & Maintenance  \  1994 Ford F-150 Shift and ABS problem
Found the problem!! The part I replaced only fixed the cruise control, turns out it was a $.50 fuse that controls the warning hazards and break lights. Go figure. After spending nearly $75 trouble shooting. Oh well I did fix the cruise control, so all is not lost.
Thanks for your help.
Lew Patten
posted by  lpatten
Congrats! But why did the fuse blow in the first place?
posted by  srober32
I have a 1994 Ford F-150 4WD 5.8 Liter that i couldn't shift out of park. I located a sensor on the master cyl that had fried. I picked up the parts needed to replace and did so. My ABS light is flashing 11 times then a steady light for a second then 11 times over and over. I assumed that the fried sensor was causing the problem, but it dosen't seem that that is the case. I still have the same problem. Engine starts fine, but I cant take it out of gear ( I know I Have To Have My Foot On The Brake) to shift. Does anyone have a answer or what the 11 flashes might mean.
Confused
i'm stilll looking at this and wondering how the fuse fixed all this
i've actually seen it happen before on the same kind of truck...
posted by  dodger65
i guess this is another reason i dont own a ford :laughing:
i must have angered the automotive gods, b/c my wife has an escort that won't go away. she just makes me give it life over and over again...
posted by  dodger65
i should be nice to ford i have owned 3 in the past and they were very good to me $$$$
88 mustang 4cyl put a trans in and drove for 4yr no problems payed 400. +500 for trans and sold it for 500.00
88 ranger 4 cyl got it free complete front suspension shot replaced it all and drove for 2 yrs and sold it 1500.00
but the best was the 2000 f150 nice truck had to trade it in on two vehicles
97 malibu and 99 caravan (family first) :laughing:
for the record, my free 83 mustang ran much better after i got pissed and ripped the ford emblem off the grille
posted by  dodger65
Bwaaahaaaahaaaaa! Was it free 'cause it was "Found On Road, Dead"? :laughing:
posted by  srober32
as for one thing that i see WHOEVER the person is that is named SROBER32, they only post smart remarks that i have seen on most of the peoples questions, ok so much for that
what i have seen in the past is the shifter has a solinoid on that is activated when the brake lalmps come on so make sure your brake lamps come on before spending money, could be a blown fuse to the lamps or ford has a problem with the green wire at the brake lamp switch that breaks just shy of the male wire connector check that also with the ABS there is a switch , in most cases, on the master cylinder or on a brake line just off the m/cylinder that deactivates the c/control which ford has had some problems with (fires) check that with an ohm's meter it shold show 0.00 ohms through the connectors on the switch, if it reads anything else its bad
ppauley/cobra freek
P.S. i have 9 ford products and all of them give me fantastic service
posted by  ppauley
You should really find newer threads :wink2: :laughing:
posted by  99integra
...so there's 9 good ones... :laughing:
since fords are so cool, is that why you know about all of the ford problems associated w/ each model? :wink2:
ps --and yes, let's do some newer threads where people probably haven't junked the vehicle yet...
posted by  dodger65
