85 FoRd BrOnCo 300-6cyl (won't fire)
Home  \  Repairs & Maintenance  \  85 FoRd BrOnCo 300-6cyl (won't fire)
I stopped at the bank one day, shut my bronco off and it ran for a bit then finally shut off (like the timing was out). 5 minutes later I go to start it and it would turn over fine but won't fire at all. I checked for spark, no spark, tested the coil and it was good. I got it towed home and pulled the cap off the distributer and turned it over and the rotor wasn't turning. I know the timing gears are good, i checked them too. could it just be the rotor? HELP!!!
ThAnKs!!!!!!undefined :doh:
posted by  DaMiEn_0607
either the little pin in the dist gear has sheared or the dist shaft broke
or gearing between dist and cam wornout
