Problem with 89 Taurus,, Help???
Home  \  Repairs & Maintenance  \  Problem with 89 Taurus,, Help???
OK, I just put a 2nd engine in my 89 taurus. Here's what it's doin. It's a 3.8 by the way. It is idling high (around 2 when normal is below 1), and if I put it in drive or reverse, it wants to go by itself like it's giving itself gas and I don't eevn have to push on the accelerator. If I an at a red light (did this one time when I had to move it, I sit on the brake waiting for the light and the car is giving itself gas wanting to do so I am holding the brake but it's trying to go all alone. Any idea what the prob is here? I figure something wrong somewhere with fuel lines or something?? Any help anywhere????
posted by  clancaster23
3 posts of the same?.... 8O
posted by  BavarianWheels
3? I only posted it in 2 different forums cause I wasnt sure which to put it in ;)
Well let's see. Your second problem is nothing more than a symptom of your first problem. Of course the car will try to "go all alone" if the idle speed is near 2000 rpm.
So why is the engine idleing that high. Well, there are several possible causes, none of them easy to diagnose online. Did you have someone perform this job for you? If so simply take it back to them and have them make it right. If not, let me know and we'll see what we can figure out.
Try looking in the Domestic Cars forum...there are two of the same there... :?
Carry on with vwhobo.
Thank you for your support. 8)
i HELPED THE GUY PUT THE ENGINE IN AND now he is unable (bad health) to do anything more with the car. Anything you can tell me to check/do would be helpful.
Check in this order;
1. Vacuum leaks, this sounds like a fairly big one but maybe not.
2. Throttle linkage, possibly the throttle valve isn't closing all the way. Look for misadjusted or kinked cable.
3. Timing, if it's too far advanced the idle will never be happy.
4. Check for codes with a scan tool. Any of these items and more will show up as a code. Really this should be your first step but I'm guessing you don't have a scan tool.
"Vacuum leaks, this sounds like a fairly big one but maybe not"
Are you talking about the hose tha goes from the air filter to the engine? And what do you mean by it sounds like a fairly big one??
I do notice when I turn the engine off, I hear a humming sound like when a vacuum has something over the hose of it. A loud humming sound for a second.
"Throttle Linkage"? I know next to nothing about under the hood of a car (hence why I post my problem here). Where is this linkage and what should I do to see if it's working right.
"Timing" Check this with a timing light I assume? If so, how do you adjust it if it needs adjusting?
No scan tool. How do I, if possible, obtain one? If it needs to be purchased, whats the average price and where to buy?
Is the high idle the reason it's wanting to go itself? Cause for some reason it's consantly giving itself gas?
Thanks for all your help also.
Look, there's no nice way to say this. From your response it's obvious you're way over your head when it comes to troubleshooting or even basic knowledge of your car ("I know next to nothing about under the hood of a car"). I can only explain so much without getting into Auto Repair 101 on this forum, so...
You and I will both be time and money ahead not to mention much less frustrated if you have someone who is a qualified tech diagnose and repair your car. Good luck.
check and make sure your throttle cable is clear of everything in your bonnet, if your car is fuel injected, get your injectors checked they may not have shut proberly or may have a slight hole. thats all i can think of.
strange problem
posted by  stringer001
1. He has already said that he has no idea what the throttle linkage looks like.
2. I a fuel injector leaked or had a hole in it, the engine would run extremely rich and try to die, not idle high. I'm surprised you didn't learn that in school.
sorry my bad, i shouldhave read the entire topic to read about the throttle linkage, and if the fuel injecter did have a whole it would be putting petrol in and keeping the revs up.
No, it would cause it to run rich and want to die. You need airflow to increase idle speed, a leaky injector does not provide that.
<<<<<<<<<<<<<<is extremely lost with all this technical jargon
posted by  SuperJew
yup
*/random spam*
posted by  asa67_stang
*/ me does my homework and realise that i am wrong, vwhobo is always right.
Not always... But the odds are in my favor.
Just curious, was it the IAC?
posted by  medicTA
