engine knock when started
Home  \  Repairs & Maintenance  \  engine knock when started
hey everybody i bought a 2001 sunfire with 68 k on it ,theres a 2.2liter engine and standard transmission.When i first start the car in the morning it knocks for about 2 minutes then its ok.Is this a serious problem or normal.
The dealer said it was normal because it takes time for the oil to build pressure and circulate.
thanks for any replys
posted by  fournier
is it a knock or a tapping/ticking
lower in engine knock (bearings or piston)
tapping/ticking (cylinder head) bad hydraulic lifter takes time to reprime itself
Possibly piston rock which is OK if it goes away when at normal operating temp.
piston slap in a 4 yearold car is a bit of a worry. Mind you I have a three yearold LS1 that ticks away until warm and that started after 12 months.
Two minutes seems like a long time for 5w30 to get into the motor. Make sure that you have the right oil in the engine.
posted by  srober32
Seriously. Taking over 5 seconds to maximize pressure would scare the crap out of me.
