97 ford taurus fan blade not turning
Home  \  Repairs & Maintenance  \  97 ford taurus fan blade not turning
Im getting alittle smoke coming from the engine. I turned the car off, popped the hood and looked to see where the smoke was coming from and i noticed the fan blade is not turning What is causing the fan not to work, what are my options.
posted by  Anunnaki
its an electric fan check to see if the fan spins freely and the motor is not siezed then check the fan fuse then temp sensor/switch for the cooling fan relay then the relay then the fan motor one of these has failed in the curcuit
