timing chain woes
Home  \  Repairs & Maintenance  \  timing chain woes
I have a 95 pont. Grand Am with a 3.1 liter engine, it has 96,000 miles on it. I recently replaced a timing chain and water pump, now the bottom end seized up. do you think there is a connection or just bad luck ? :ohcrap:
posted by  racer 34
BOTH DID YOU HAVE A MECHANIC CHECK IT OUT
p.s. DID YOU JUST JOIN?
posted by  google.com
I guess you were careful not to rotate the camshaft from it original position, relative to the crankshaft? Do you think the engine overheated? Is your oil level correct?
