abs brakeline routing (dodgeintrepid)
Home  \  Repairs & Maintenance  \  abs brakeline routing (dodgeintrepid)
hello,does anyone know if bottom lines on output side of abs valve(assy) are too the rear wheels,top ones for the front?...which are LH,RH...runing new lines not going with factory routing...factory lines buried b-hind eng/trans..thanx 4 any help
posted by  intrepidbrake
a shop manual will probably help
disconnect the old lines at both ends and blow compressed air through to tell you which is which...
posted by  dodger65
