2000 hyundai accent shaking
I could hear a clicking noise going on for a couple days, but pretty much only when the car first started,and now it shakes really hard when im up above 50mph. The shaking is so bad you cant really see out the rear view mirror, the steering wheel shakes as well. Last night the check engine light blinked a few times. Help. Please.
Are your tires balanced? That can cause your car to shake when you go at higher speeds.
Yeah that may be one thing but he said that when it first started up it made a clicking sound and now the car is shaking in excess of 50. I would have to go with the idle being to high. :2cents:
check your tires/wheels... if it's that bad it should be visible...
does it click more when going around corners?
just go to your dealer, you are or should still be covered under warranty
if you are the original owner.
chris
i took it to the garage, and i needed new tires and new...rear...spurs?..struts?... i dont know something like that.
Glad to hear you found out the problem. :thumbs:
