Diagram of 92 Dodge Caravan fuse box?
Any one have one? Specifically where is the fuse for the cooling fan? THX!
It should be in the owners manuel or you could go to the dealership and they could give you one :thumbs:
We don't have the manual (second owners) and it's our only vehicle right now as the other is getting fixed as well. . . .when it rains. . . . .
Hmm, well in the fuse box the fuses should be labeled no matter what car it is, other wise there really isn't any other way but to go to a dealer and get it from them
there may not even be a fuse for the cooling fan. if it isn't kicking on
put 12v to it and see if it turns. if it does you probably have a bad
temperature sender or coolant temperature sensor (forgot which one runs the
fan)
so what exactly is the problem?
Here try this:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d
/80/10/cc/a4/0900823d8010cca4.jsp
