Honda Accord 1996 A/C R12a Refrigerant to refill R134a
Hi,
In the past two years my A/C system been checked twice for leaks with
negative results that is, they couldn't find the leak point. They'ld
refilled it with R134 (by an amount of 24 oz) and with that the A/C would
work for the rest of the summer. The August of 2004 was the last time I
had my A/C checked and once again, this summer, the A/C is not producing
cold air. Assuming that the leak is small and that this year too I have
only lost an amount of the refrigerant similar to last year (24oz) I bought
the RedTek 12a Recharge kit (which contains 2 cans, each equivalent to 16
oz of R134a). I did not realize that the refrigerant in my system was R134A
and as they say is it illegal to mix it with a different type like the R12a
I bought.
The literature I was able to find in the internet site for RED TEK says: DO
NOT MIX REFRIGERANTS. Mixing refrigerants is illegal in Canada and the US
My questions are:
Does anyone know the total amount of refrigerant in the A/C system for the
1996 Honda Accord 2.2L?
How can I measure the amount of refrigerant lost?
Why is it illegal to mix refrigerants when they say that the R12a is
compatible with most existing refrigerants?
Should I first have the A/C system checked again by a certified garage and
request that it is refilled with R12a so that next year I can refilled it
myself in case it leaks again?
What are the risks of mixing R134a with R12a?
I will appreciate any help.
Regards
G.
If the car was designed for R-134a, use 134a
the number of oz. the system takes should be on a sticker on the hood. 3lbs or so?
It says it is compatible because it contains the same oils as R134a, but I
wouldn't use it if your car already takes R134a (which it should) since
R134a is readily available just about at any parts store. R12a is mainly
used as a replacement for r12 (freon) which has since been illegal to use
without a license (and it's about $30 a can as opposed to $10 a can for
R134a). You don't want to mix refrigerants because some formulas contain
different oils which can damage your a/c unit and the system will not offer
the maximum performance of your system. R12a contains the same oils but
Redtek actually recommends a full evacuation of your system prior to
filling with r12a.
P.S> for a 1994-97 Accord it is 650 grams (23 oz.) refrigerant to fill
and an extra 2 oz per hose on the evac refill machine ;) dont forget that it sux having to go back:( is r12a common where you live cuz all it is here is r134a
one can recharge 134a without a certification card but one has to have one to remove any refrigerant (a reclaim machine must be used) as well as to buy any quantity of R-12
i would try to find that leak. i was reading the redtek website.. it says
u need to charge the system to 33% of r12 capacity. its gonna be hard for u
to find a shop that service this gas.. remember if there is a leak, air got
in. ur cooling wil be limited.
edit: oops. u need info on amount compared to r134a..
http://63.135.115.175/techinfo_char_wt_charts.html#
6oz = 1 lb of r134a
