1998 Eclipse GST transaxle noises
Just wanted to see if anyone else has some knowledge of this issue. Could
there be something broken in the manual transaxle that sounds like a wheel
rubbing yer fender when turning to the right (uphill) under power ? Going
over speed bumps can aggrivate it enough that it sounds constant, then
eventually goes away?Last speed bump produced a low knock from transaxle
area, Also another issue while turning to the right is loosing some power
in acceleration, until I let up on throttle,it then immediatly returns to
normal. Just recently had car lowered ,Took it to dealer, they could not
diagnose because could not reproduce sound, that was before I realized that
was happening more dramatically on speed bumps. I was tellin them to listen
while turning (1st symptom) :banghead: thanx....
