93 mazda 929 alarm system
my son just bought a new car and the man says the car waz runing fine. something happened to a fuse or something so he took it out and set the alarm off and he could not cut it off so he undid it and now the car will not start but it will trun over. it is like the fule pump is not comeing on or
something it is a v6 with twin cams will the alarm system have any thing to do wtih this i can take the alarm box out but it will not start does the wires tie into the fuel pump can some one one help..............AND NO I AM NOT TRING TO STILL A CAR BUT IT DOES SOUND LIKE IT........LOL :banghead: :banghead: :banghead: :banghead:
posted by  leejj
Could be a dead battery, jump it and see if it turns over
posted by  99integra
lol can u read i said it will trun over so that tells u the batter is good and not dead if it waz the batter it will not trun over but just a little but it truns over good and it has a new batter in it i do know about cars. but not a mazda never had a mazda.first one.. :screwy: :screwy: :laughing:
posted by  leejj
It is most likely an immobiliser built into the alarm... They make it so it turns over, but won't start .... something about thieves trying to start the car, can't, so they leave it. They seem to think that if the car doesn't even turn over, the crooks are more likely to look for an immobiliser switch or something.
Don't have time to go through a detailed response now, but will try to a little bit later.
posted by  windsonian
true that is what happening to the car. can i bypass it somehow are do i got to find every wire to the alarm and take it out and run new wires.can u plz help i dont have 1100 to take to the shop and they said they could not help me with it they did not know what i waz talking about so they had to look at it.i will rewire the hole car if i got to lol.... if i go out and buy a book will it show me on wiring it up.that will be alot of work omg will it :banghead: :banghead: :banghead: :cussing:
posted by  leejj
is it a factory fitted alarm or a custom job? if it's factory fitted, you should be able to get a wiring diagram in a maintenance manual.
maybe you can try resetting it if the alarm is a factory alarm...im not sure about mazdas, but on pontiacs, you leave the ignition key on the "on" position for like 10 minutes, turn it off , then try to start it...may work, may not...give it a try
posted by  Lithium
My keyless entry is supposed to be connected to my ignition so that if it is set to locked on the module, the car wont start. I would try resetting the alarm if you can. I have a little valet switch for mine. You just stick the key in to the on position, hold the button for so many seconds and then click a button on the remote pad.
posted by  Nickboxer7
yeah, some are like that, but some need weird codes like turn the key from off to accessories 3 times, then on and off 12 times, then the car will start.
iwll try this things to see if it will work and let u all now what the outcome is
thanks for all the info guys............. :thumbs: :mrgreen:
posted by  leejj
