83 Plymouth Turismo
83 Plymouth Turismo
Hey all, my name is Victor and i am 17. A while ago i had a old plymouth
turismo, and this is when i didnt have me license, so another family member
was driving it. All i remember is the head gasket needed replacement(which
i can do now) and somebody also put sugar in the tank :ohcrap: and its
been jus sitting around, and i thought what the hell might as well have
some fun.
Ok what I need to know is, what parts would i have to replace and or fix to
get her running again? All i know is i already have to get a new gas tank,
and the fuel filter will need to be replaced, spark plugs....and the
carberator will need to be cleaned.
Please add to this, and/or correct it. Thanks everyone
can someone please help me out?
your on the right track if the tank is in good condition then just flush it
out after you drain the gas and let it air out for a day to evaparate the
rest
you will need to clean the carb flush the lines/drain replace fuel filter
any idea how much the engine ran with sugar in the tank?
always thought this would ruin the engine i've never seen it only heard
about this stuff happening
yeah i couldnt believe it when it happened, it wouldnt if i was driving it
because id probably be sleeping in it or something ahaha
Ok but i just want to make sure its worth my effort and money, because im
not loaded with cash at the moment. I hope tht will make it run, but if
theres anything I missed or you guys think will help please tell
me......and also tell me if it totally gone, thanks
And thank you for your reply
oh sorry i didnt answer your question, um i think it was a month or something......but im not 100% sure how long it was
please can someone help finish off my questions, also i wanted to ask do i clean the carberator with water or carberator cleaner.....because on the bottle of carberator it says to clean the insides while its running.....but i cant get it to run right now
Rofl Water, Mos Def Do Not Use Water!!!! Use Carb Cleaner Spray. And U Usually Do It While Its Running, But U Can Do It Off Too. Only Problem Is By Doing It Off, Ur Risking The Chance Of Flooding The Carb.
whats wrong with water?
I wonder how long it took this person to type that. It Took Me 25 Seconds
To Just Type This Sentence. My goodness...
Oh and duh, water wont hurt the carb as long as its off the engine, just
make sure you dry it out very well so as the carb wont build up rust or
anything (depending on how long it will sit)
thank you for the replys.....i guess imma use the carberator
cleaner....imma have to jus turn it around and stuff to pour out the
cleaner stuff
so i only have to change the gas tank, and fuel filter and lines, and/or
clean the lines.....and clean the carberator and the engine should start
running?
hopefully i get a quick reply to this
thank you
I wouldnt see why it wouldnt...I have never seen what sugar does to the
engine, but maybe it could eat the diaphram on the fuel pump, so it may
need replaced. As long as the sugar didnt harm any internals (valves,
pistons, bores) then i dont see why it wont start.
Good luck and let us know how it turns out.
thank you
now i have no problem buying new lines and a new fuel filter, but gas tank
will be a problem....is ther anyway i could test it with a bottle of
gasoline?
maybe connect all the line into a small container with gasoline just to try
it out?
thanks for the help
Um....I thought you said the head gasket was bad?? If it is I wouldnt bother trying to get it to run until its fixed, because your engine isnt going to run very well (or at all) on a bad head gasket. but if you are going to change the head gasket, check the bores and your pistons, valves, etc. for damage from the sugar(?) Who puts sugar in a gas tank anyways, maybe as a octane booster? :screwy: lol j/k
i wanted to get it running first, and if it ran....id change the head
gasket
i dont want to replace tht and end up knowing that its not gunna run
Can someone please help me out with testing the engine without a gas
tank?
thanks
depending on how bad the head gaskets gone you should be able to get it to
run/start up/stumble/etc
as for the gas in a bottle it will work if the engine has a mechanical fuel
pump
or hook up an electric if need be
Alright....does somebody know if a 1983 Plymouth Turismo uses a pump or
not?
Also i was talking to a mechanic, and he said it would cost lik 500 dollars
jus to get everything cleaned in the engine to get it working.....isnt this
BS, like seriously changing the fuel pump, lines, and cleaning the
carberator with a cleaner, and replacing the gas tank cant cost 500.
This is all i found out that i have to do, so to my knowledge, all sugar
does is clog up lines and the carberator...
Ahhhh im hoping this will be worth my effort!!!!!!
thanks again
no more advice?
google it....
...or follow the fuel lines.
Ok ill do that, i guess i was being kinda lazy there
So can i just get my other questions ansrewed please?
Im thinking about starting on it tommorrow
hmm nobody has replyed to this yet, but i have another question.....a very
stupid one
the fuel lines are made out of metal right.....so when i take them
out...should i clean them with penatrating oil or jus plain water?
thank you for the help
$500 seems like a fair price to me, dropping a tank is quite a bit of work. Thats basically asking to re-do your whole fuel system. My mechanic charged $650 just to change the fuel pump in our Buick. (on some cars the fuel pump is mounted in the gas tank, so that has to come out to get to it) I would say youre best off doing it yourself if you have the tools and you are capable. As for your trying it out, maybe just squirt some gas in the intake and see if it does anything. Or a mechanical fuel pump will do just fine, if you have one. Electric pumps are about 40 bucks so not really worth it. Your lines should clean up fine, use a garden hose with a sprayer and squirt inside them for a minute or so to dissolve the sugar. :2cents:
thanks man
so far i have the carberator basically tooken out, the fuel lines are
almost out, same with the pump
im pretty sure imma have to buy a new pump, $$ shit lol
I hope i get this running
Id have everything cleaned out by now, but the weather is cooling off a
bit, and raining, so it is kind of hard :cussing:
ok i jus have two questions
when i was looking at the carberator....i forgot the name of this part, but
its where air enters the carberator, so if you move the acclerator it will
open and close, but when i move the acclerator all the way, it only opens
like a 1cm......what could be causing this
also could i test if the engine is running if i just fill the float bowl
with gasoline and start it....or do i have to replace the fuel pump and
install the lines, and put the lines into a container of gasoline to test
it?
thank you alot for the help
bump....
If you can move the carb butterfly's, or throttle plates, by hand and it isnt stuck you should be ok. Usually if you find a fuel bowl vent hole (basically a hole in the top of the carb) you can squrt gas in there till it is full and your car should run for a few seconds. you will know when its full and working properly (well almost) when you move the throttle plates and gas sqirts out, if it doesnt after a few tries the the carb is plugged and will more than likely needs a good cleaning anyways. Did you ever figure out if it has an electric or mechanical fuel pump?
well due to the weather down here, i didnt get it out so i cant really see
it
but i could put my bets on it being electrical because its near the bottom
of the engine, and it would have to be connect to the cam shaft for it to
be mechancial doesnt it, ive also read up about some of them being run on
oil pressure
damn forcast says it should stop raining by friday
well the weather warmed up, and i just looked at the engine and i guess i
was wrong, it looks lik a mechanical fuel pump, it mounted to the engine,
no wires going to it, im pretty sure it runs of the oil pressure.....
this is werid because i took out the fuel lines and the filter, when i ran
water threw the filter clean water came out the other end, and theres
another line, where some water came out tht was white colored, but it
passed after about a second of flushing.......maybe this is all the sugar
in the lines? I was thinking maybe the pump must be shot, maybe thats why
it isnt running
if you can correct me or tell me im right it would be nice
thanks
no comments?
This is interesting:
I was watching this show called Mythbusters on t.v. and they did the sugar
in gas tank thing and it didnt hurt anything. The motor they used (a Chevy
350 I think) ran just fine with the sugar in it. They even let it sit for a
day to let the sugar sit and it still started right up. So good news for
you lol.
I wouldnt worry about the pump, if your carb is good and the engine isnt
locked up (or has major mechanical problems) I think you will be just fine
squirting gas into/through the carb and see if it will start/cakle/fire or
do something that tells us it has the potential to run. When you get there
we can help other than just "pissing in the wind". :laughing: Throwing
money at a car just to find out its junk isnt very fun. :2cents:
wow thts interesting, hmmm it makes me wonder why it stopped running then
eh hmmmm
well disconnected all the lines, so i think i might leave them
disconnected, and ill try and put gas into the carberator float bowl, and
put the carberator back together and see if it runs or not.
Maybe could the engine not be running because the head gasket? I doubt tht
it makes a difference in the engine starting or not, but if it does i think
i might have to replace tht, thank you for the help
oh sorry i kinda misread your post, ok ill try it and let you guys know if it kinda runs or not
