1998 VW Jetta blower motor
Home  \  Repairs & Maintenance  \  1998 VW Jetta blower motor
Yesterday my blower motor did something very strange. It only blows on High (4) also when the AC button is pushed in, it (the ac) shuts off when the fan is set to high. The AC stays "on" on 1 thru 3 but no air flow exists. Do I need to look at replacing the blower motor?
Thanks in advance
Sherman
posted by  swells
If your blower motor works on High then the blower motor works, it is most probably a wiring problem, so I would advise checking the switch if it works and then all of the connections from your switch to the blower.
posted by  Arbitrary
