1996 Chev. Lumina APV - No brake lights?
I just recently had a remote starter installed on my van and a day or so
afterward I noticed that the brake lights weren't coming on when the pedal
is applied.
I briefly looked at it myself, nothing I could see wrong, but since I'm not
that great with electrical issues, I took it back to where I had the
starter installed and watched them check the whole thing out. Their
wiring/installation does not appear to be at fault. We've checked every
fuse, all the remote start wiring. The brake pedal switches are getting
power, and the rear bulbs are all functional. However, pressing the brake
pedal does not activate the brake lights, except for the one that's in the
center of the tailgate...but the main ones do not illuminate.
The guy who wired up the starter, after checking everything out, called one
of his tech support people and they indicated that this model of car has an
issue with a "switch in the steering column" that has been known to cause
this problem, or something? I can't find any relevant data pertaining to
this "switch".
Anyone have any thoughts, or access to information that might lead to a
conclusion about this, before I have to put the van in for diagnostics?
Thanks, any help at all will be appreciated.
Never mind, cause of problem discovered.
