1994 Lincoln Continental Signature water pump change
My 94 Lincloln is about to toss the water pump as the pulley is wobbiling badly and the bearings are grinding. Does anyone know if the engine has to be lifted or can it be taken out like it is? Thx in advance......
assuming continental?3.8?
remove both lower nuts on right side engine support
raise and support engine
remove belts and water pump pulley
power steering pump(leave lines attatched)
remove front ac bracket leaving pump in place
now take off coolant hoses
install in reverse order
mark viii and town car
remove fan and shroud
release belt tensioner remove belt and pulley
take pump bolts out water pump and o ring
thank you windman
your welcome
