Hotwire fuelpump?????
Home \ Repairs & Maintenance \ Hotwire fuelpump?????
Hi Everyone, I need help with why the fuelpump on 94 ford explorer is not getting power? ive change the relay, reset switch and still nothing. fuelpump works if i stright wire it. could the after market car alarm ,"i dont have the remoute" be the promble? thanks ,brew
Did you check all the fuses? Not sure if the Ranger has a fuse panel under the hood also but if it does check all those fuse's to. Yes the alarm could cause the problem depending on how it was installed. Start with the fuese and go from there.
