Interference vs. Non-Interference engines
Good morning folks,
Does anyone know of a website that I can go to and look up various vehicles
and engines to determine if they are interference or not? I've been
looking but no luck yet. Thanks! :thumbs:
Hmmm. Try Gates (as in belts). I seem to recall seeing that somewhere on there site.
I am so f*cking smart sometimes. Here is a chart listing interference
engines that run belts. Good luck finding a truly comprehensive listing
online.
http://www.gates.com/downloads/download2_common.cfm?file=TimingBeltReplaceP
ages.pdf&folder=brochure&CFID=2502651&CFTOKEN=90780336
Here I go again. What exactly is a interference engine vs. non inteference ?
Very simple grasshopper. An interference engine is one where the valves
when open will touch the pistons at TDC such as when the camshaft timing is
out of sync. This could occur if the timing belt or chain breaks, is
incorrectly timed or someone is moving the cam or crank with the engine not
fully assembled. Obviously a non-interference engine won't do this.
Keep in mind this is for a stock engine. Modifications such as changing
the valve timing, valve lift or compression ratio can and does turn some
non-interference engines into interference engines.
Okie Dokie, I understand interference engines now. Maybe I don't have the need for you to go into non-interference (little confused). BUT, if you want to elaborate on the later, I would be more than happy to read, Hell, someone else may too. I know how much you love to type :laughing:
Thank you VWHOBO.....I could not find any comprehensive listings either but I am going to check this out right now. Again, thanks for your help and thanks for saving me the effort of explaining what Interference and N on-I are. :hi: :smoke:
Ok VWHOBO,
I went to that chart and it has a ton of info, but I am looking to see if a
1996 Pontiac Grand AM 2.4L 4-cylinder has an interference engine. This
listing cannot be found on this PDF. Do you know if that motor is
Interference? Thank you!
Well, if you would have just asked the question you wanted answered it
would have saved us all a lot of time. Is dealing with the sudden influx
of dipshits getting to you... Like maybe rubbing off. :mrgreen:
The simple answer to that simple question is affirmative.
Well I have a few engines I wanted to look at so that is why I wanted the listing. :smoke: The immediate need though was for the 96 G/A. So thank you for your answer, I figured it was. :doh: Thanks again! :thumbs:
Vw,
You ever done them on that DOHC engine, the 2.4L? I am sure you have, are
they a M/f'r to do? Looks like it due to clearance. Was thinking of losing
the passenger motor mount and passenger tire and inner fender liner that
covers the crank pulley, etc. I want to do it preventativly and prolly
throw a water pump at it while I am in there, what do you think? Thanks!
You would be correct in your assessment. Mechanically and technically it's
a very straightforward job. Clearance IS the issue. Just take yor time
and walk away when you get pissed off, and you will get pissed of.
It's a good call to replace the water pump while you're there and just in
case you did, don't forget to replace the tensioner and guides a well. You
can get the whole set for just a little more than the chain alone.
Oh god I KNOW I will get pissed off. I will have to try not to start
throwing things, LOL.... :hi: I will end up saying :fu: to that car more
times that I have hairs on my head because I have already looked at it and
figured that with the motor mount gone, I will have to raise and lower the
engine numerous times to get to all the bolts, etc. Mechanically it is
easy. Oh, in your posting you said "chain?" I take it you meant belt?
:hi: I just had to get on you for that one based on your "proper
terminology" arguements. :laughing:
Thanks for the help and info. :thumbs:
Vwhobo,
Before you land blast me, let me correct myself. I "thought" that 2.4L had
a timing belt but it DOES has a chain. I thought you just mis-spoke when
you said "chain" in your previous posting to me because I have refered to
the "belt" in all of my postings. Well hell, if it has a chain; I only
have 50-55K on the engine; She isn't coming apart then unless I start
having a water pump problem. Screw that, I thought I had a belt and was
going to preventatively replace it here in the near future, esp. being an
interference engine. Thanks for the help and again, my bad, I thought
youoff when in fact, I did not realize I had a chain BUT the dealer
confirmed it for me. Thanks :thumbs: :thumbs:
There is a list for timing belts at:
http://www.gates.com/brochure.cfm?brochure=981&location_id=540
But does naybody know of such a website for timing CHAINS? My 1988 Beretta
(2.3 L V-6) just broke a timing chain and I was wondering if it might be
worth me reparing. No way if it needs valves too! It died at freeway
speeds! At least that is what I think is wrong as the starter now spins so
fast as if no load at all. I assume there is no compression. Does GM still
use those silly nylon sprockets?
-Don-
That is not good. Your engine should have compression still and if the starter is spinning the engine over like there is no load, you have more than likely blown the pistons through with a valve/piston collision. I would have to check more into it, but when the timing chain/belt breaks, you do not lose compression. Granted the valve train does bring some level of resistance to the starter and adds to the compression, it is not enough to make the motor spin totally free once the chain/belt is no longer connected.
Remember the timing chain is broke, that equals stuck open valves which equals no compression....
Yes that is very true, that went right past me for some reason :doh: .....if it is an interference engine though, it may be severly damaged....if not, then there should have been clearance for the pistons and valve train when they were out of time with one another. Great call...I was not thinking! :ohcrap:
