right wheel locks up
I have a '84 chevy citation with rear drum and front disc brakes
The emergency brake(parking brake) is foot pedal actuated. This is a left
hand steering wheel car and the emergency brake foot pedal is on the left
When the emergency brake is applied the right rear wheel locks up and the
brake on the left rear wheel is only partially applied(it never locks up)
This is on dry pavement.
The brakes have been done a year ago with new drums, new shoes and new
emerg cables(all 3 of them). There is a equalizer on the rear axle where
the emerg. cable goes into it and from there it splits to either rear
wheel. There are no worn parts anywhere to be found. As far as the brake
drum adjusters go, they are adjusted until the drums just drag (with a
loose emerg. cable of course) So as far as I can see I've done everthing
right or have I ?
Got any ideas why the braking is so imbalanced??? I've tried everthing
try tightening the cable to the left rear wheel see the pic the cable is to slack
This is pretty serious stuff so I wouldn't tweek with it without being sure of what I'm doing and if I should be doing it. I would just take it to a mechanic. If you don't want to spend the money on that, just privat message hobo. I heard he responds to PM's and he's an ASE mechanic so he'll be fine figuring this out.
Hobo's not the only licenced tech here so go smoke a tailpipe :banghead:
osborst says
"try tightening the cable to the left rear wheel see the pic the cable is
to slack"
I've tried that. The cable adjuster tightens both wheels not just one
:banghead:
So why is it you very seldom have a remotely correct answer? He even told
you the e-brake cable has an equalizer and you still f*cked it up. You
can't adjust them separately.
How are the service brakes? Any pulling or locking? Have you removed the
drums and visually inspected the assemblies? Contaminated shoes? Proer
placement of the primary and servo shoes?
cargrease I have the very same problem!
I own a 1986 chev cavalier and it has the same brake system as your car. I
can tell from your post that you are totally exasperated by this
problem.
My right wheel locks up when I push on the foot pedal but the left wheel
does not. At first I thought it was bad brakes. I have a mathematical back
ground so I ventured to see if I could apply some math to the problem.
First I disasemmble the parking brake system and had a good look at it. I
noticed something peculiar about how GM has designed this and recalled a
mathematical thing called the "force vector" was the needed tool to obtain
the understanding of WHY.
First the cable that comes from the foot pedal, we'll call it the "main
cable"
The main cable goes from the foot pedal to a mechanism called an
"equalizer" .This equalizer sits somewhat loosely near the center of the
rear axle. From the equalizer there are two cables, one goes to the left
wheel and the other to the right wheel. The angle that the main cable makes
with the cable going to the right wheel is greater than 90 degrees, and the
angle the main cable cable makes with the cable that goes to the left wheel
is less than 90 degress. So the tension of the cable that goes to the
right wheel is the SUM of the horizontal and vertical components of the
main cable tension and the tension of the cable that goes to the left wheel
is the DIFFERENCE of the horizontal and vertical components of the main
cable tension.
The result is about twice as much force is applied to the right brake as
compared to the left one. And there is not a thing you can do about it as
GM has engineered that problem into the parking brake system. :clap:
I must admit my car knowledge is too weak to suggest a solution to this
problem but as a high school Physics student, I find your explanation very
interesting. I just have one question. If I understand correctly, the main
cable goes to the equalizer from the foot pedal. It is then connected to 2
different cables, one going to the right wheel, one to the left. How is it
possible that the angles are different if the 2 wheels are parallel and the
2 cables go from the same point that is about equidistant between the
wheels? Or am I just not picturing something correctly?
PS This freezing problem on CF is horrible...good thing I finally
remembered to copy and save.
Maybe there is a pully system. Not sure of that myself. With that kinda attitude you might ask how teh transmission is in the engine bay, and the shifter isnt right parralel to it. Its just hot its set up.
Nissan altima says
How is it possible that the angles are different if the 2 wheels are
parallel and the 2 cables go from the same point that is about equidistant
between the wheels? Or am I just not picturing something correctly
It would help to see the actual GM parking brake system on these cars. The
2 different angles will be readily apparent
I'm not reffering to the angle between the right and left cable.(There is a
small angle here though, but I was not reffering to it) To be more
specific, it is the angle that the main cable makes with the rear axle.
This is NOT a center pull type of parking brake as is found on the better
systems.
I had a Toyota that had a center pull hand brake. When you pulled the lever
both rear wheels would lock up everytime on dry pavement
this is what i was trying to refer to as the center and right rear cable tighten and apply the right rear brake assembly then the left rear cable will start to tighten applying the left rear brake
