Monte carlo LS
i have a 1995 monte carlo and their is a shortage in the bright lights switch that cause the brake lights not to work what should i do
Huh? Start here (http://www.car-forums.com/talk/showthread.php?t=2200) and re-submit.
I have a 1995 chevy lumina---almost the same car as yours. I had the same problem. The brake lights go thru the turn signal assembly in your stearing column. You either replace that or do what I did, put a small piece of plastic shim to force the two pieces of plastic together. It lasted about 50k miles before I had to do it again. Be careful of the airbag assemble in the column. Get a manual at autozone and follow the proceedures---pulling fuses, etc.
I have a 95 monte carlo and the lever for the turn signals just kinda lays
there I was going to replace the plastic piece behind the steering wheel
but cant figure out how it comes off. Can anyone tell me the correct way to
remove it.
Chris
a repair manual would be best for that.
Do you know what these are for?
http://www.partsamerica.com/product_images/img/han/24048.jpg
http://www.partsamerica.com/product_images/img/chi/28682.jpg
This is not a place for step by step instructions for those too lazy to do
their homework.
