1990 jeep wrangler clutch problem
my dad just bought a new jeep, and told me that if i fixed his old one, i could have it. it is a 1990 jeep wrangler. all it needs to be driveable is a clutch. i am looking at spending as little money as posible, so i was wondering how much time, trouble, work, ect. it would take to put it in myself.
provided you have some mechanical ability, it shouldnt be that hard - grab
a Haynes manual for the jeep, and follow instructions.
As for cost...the clutch kits can range from 150$ to over 200$... depends
on the quality, and what's included - most shoudl include the pressure
plate, cluth disc, throwout bearing, possibly a pilot bearing, and
generally will have an alignment tool.
Might want to check out the flywheel when you've got it cracked open as
well...
how much do u think it would cost to have a mechanic do it? i know i cold probably do it, but finding the time to do it would be hard. how long do u think it would take?
A mechanic would probably take 1-2 hours to do it and costing maybe around $400-500. All thats really needed is to drop the tranny, pop it in, and put the tranny back. Without a transmission jack it is hard to do. Of course it ain't as simple as just popping it in either though
ok, with all that said, what would you all suggest me doing? i really would rather not spend more than $500 doing it. what could i use intead of a tranny jack? does anyone know of any good sites that would help me?
Well when I did mine I used a piece of wood on top of a normal floor jack,
but you need 2 people to do this. They do have attachments for floor jacks
to make it a tranny jack for only about $50 or $60 (type "Transmission
Jack" on ebay. I found 2 that are around $50 each with shipping)
List your year, make, model and engine size and I can probably get a list
of instructions to help you out. Best bet would be to buy a Haynes manual
for your car though as it has good instructions and some pictures in it. If
you don't want to buy one of those I have Mitchell's OnDemand so I could
give you the instructions just no pictures
well it's a 1990 jeep wrangler 6cyl. i thought my dad had a manual but i
cant find it anywhere. he may have just borrowed it from someone tho. so i
would appreciate it if you could send that to me. thanks for the help.
also, i talked to him last night, and found out that the tranny syncs were
bad. Is there anything i could do besides rebuilding it, or buying a new
tranny?
Removal:
Remove transmission assembly. Place reference marks on clutch cover and
flywheel for reassembly reference. Evenly loosen clutch over bolt one or 2
turns at a time until clutch cover spring tension is released. Remove cover
bolts, clutch cover, and clutch disc.
Installation:
Check all components for wear or damage and replace as necessary. Using
clutch alignment tool, aligh clutch disc and loosely install clutch cover
with reference marks aligned with flywheel. Tighten each cover bolt a few
turns at a time to specification.
Torque Specifications(yes this does mean you need a torque wrench and know
how to use it):
Ft. Lbs. (N.M)
Clutch Cover Bolt: 40 (54)
Clutch Housing-To-Engine bolt:
M12 X1.75 - 55 (75)
3/8" X 16 - 27 (37)
7/16" X 14 - 43 (58)
Crossmember-To-Frame Bolt - 30 (41)
Master Cylinder Mounting Nut - 19 (26)
Rear Support-To-Crossmember Bolt - 33 (45)
Transmission Removal:
1. Place transfer case in 1st or 3rd gear. Raise and support vehicle(using
jack stands). Drain transfer case lubricant. Support engine with adjustable
jack stand. Use wood blook between pan and jack(if not tranny jck). Remove
rear crossmember.
2. Disconnect transmission shift linkage, speedometer cable, transfer case
vacuum lines, electrical wiring, and clutch hydraulic lines. Place
reference mark on srive shaft yokes and transfer case yokes for reassemly
reference. Disconnect drive shafts.
3. Support transfer case with jack and lower case. NOT MORE than three
inches. Reaching up and around the transmission case, move boot upwatrd to
access shift level retainer. Disengage shift lever from transmission by
pressing down and turning retainer counterclockwise to release it. Lift
retainer out of transmission shift tower.
NOT: DO NOT remove shift lever from floor pan boot.
4. Remove clutch housing to engine bolts, remove transmission and transfer
case.
5. Separate transmission from transfer case.
Installation.
To install, reverse removal procedures. Fill with proper lubricat. Fill and
bleed the hydraulic clutch system
Bleeding:
1: Fill master cylinder reservoir with DOT 3 brake fluid. Raise and support
vehicle. Attach bleeder hose to bleeder screw on bleed line of hydraulic
throw-out bearing. See Fig. 1. Immerse other end of hose in glass container
1/2 full of brake fluis. Loosen bleeder screw while holding bleeder screw
fitting
CAUTION: DO NOT allow bleed line to bend or flex when loosening bleeder
screw.
2. Have an assistant depres clutch pedal to the floor. Tighten bleeder
screw and release clutch pedal. Repeat bleeding procedure until fluid
entering container is free of bubbles. DO NOT allow reservoir to run out of
fluid during bleeding. Refill clutch master cylinder to level mark on
reservoir.
There is also how to change the Hydraulic throw-out bearing, pilot bearing,
and clutch master cylinder if you need that too.
http://www.boomspeed.com/dragonsilver/fig1.jpg
Thanks a ton dude
