plastic bits in my timing case?!
Home  \  Repairs & Maintenance  \  plastic bits in my timing case?!
replacing a very worn cam sprocket on a zd fairlane 351 cleveland motor when i found broken plastic bits matching the profile of the sprocket! Anyone know the story here? Also, do I really need to replace the chain as this looks quite fine?
posted by  diyo
error
posted by  diyo
Wtf???
vw's? aren't they those things you drive if you want to self immolate?
posted by  diyo
No, they're cars to drive because I wouldn't be caught dead in a POS Ford.
:laughing: :laughing: :laughing: You got that right :laughing: :laughing: :laughing:
posted by  lectroid
On with the show.
You seem to know about 351s vdubya, did they originally come with a plastic or nylon timing chain sprocket on the cam shaft?
posted by  diyo
Correct you are, I am familiar with the Cleveland engine. I am also familiar with the "Introduce Yourself" section which is the starting point for all new members. See ya there.
Hi
All stock vehicles made in that era have a nylon coating on the "ORIGINAL"
cam sprocket to lower noise from that area. The problem is that they tend to
crack and break up after a few years, 70000- 100000 miles. If your cam
sprocket is all metal it was replaced previously and a neglectful mechanic
didn't remove the peices. (Sometimes they fall into the pan and Oh well what
are they going to hurt). Get rid of the peices and go man.
posted by  hitchhiker
[QUOTE=hitchhiker]Hi
cam sprocket to lower noise from that area. QUOTE]
Thanks hitchhiker, you'll get a lift anytime. I suspected as much or similar but I had it confirmed when I ordered the replacement parts. I reckon this beast ('71, original motor) has probably clocked around 2 or 300,000(miles). It was on first size rings and bearings when I went over it about 4 years ago. Hopefully we'll go another 100,000 before it's first major reco. See ya on the road ;)
posted by  diyo
