So Far No One Knows Why My Dodge
Home  \  Repairs & Maintenance  \  So Far No One Knows Why My Dodge
I HAve a 1993 caravan i want to buy. it has a 3.3 engine that will crank then idle them crank then idle then crank ect. it idles for about 2 seconds each time then dies. got the right fuel pressure. tried different brain too but no change . it will run only if i pump fast on the petal but real roughly. :cussing: any ideas>>>>>>??????????? tom
posted by  JUSTICE
There is a dedicated section called "introduce yourself".... USE IT :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
posted by  R34RB30DETTV
thank you for your help
posted by  JUSTICE
You need to introduce yourself
Next, this is a vehicle which needs the attention of a dealer service department since it should still be under warranty unless it has over 36K miles. It will also be under emmissions warranty for a longer period of time unless someone has abused it, modified it, etc. Although the emmissions and powertrain warranties usually transfer to a new owner, why would a person want to buy a car knowing it doesn't run?
it is not under warranty it is in good shape and it is cheap and so am i
posted by  JUSTICE
my mistake - I was reading cross eyed and thought it was a 2003.
no problem
posted by  JUSTICE
I had a 1986 dodge 600 2.2L turbo which did this when the hall effect pick-up plate in the distrubutor failed.
A good starting point would be to retrieve the trouble codes. There is a certain sequence of steps on a Chrysler to follow where these codes can be pulled without a code reader. I don't remember what these steps are but can look them up when I have a little more time.
Ever wondered why it's for sale? :banghead:
posted by  Cliffy
