Replacing Ignition Module in '91 F150
Hey guys...
I have a 1991 F150, 300, which shut off on me three times in just a few
minutes while driving down the road. After the third shut off, everything
that should have happened when I turn the ignition didn't. Headlights and
cargo lights worked, but nothing on the dash. We narrowed it down to a
possible problem with the ignition module (correct me if this sounds
incorrect). There has been some speculation about the fuel filter, but I
don't see this effecting anything electrical in the dash, and it doesn't
even try to work when I turn the ignition. Not to mention I've suffered
several "fuel filter breakdowns" in the past and this was nothing like
that.
I dove into the problem myself, seeing as my mechanic is out of town for a
month and I dont have the money to pay for a towing + some expensive
mechanic. And it seemed like it would be easy to fix.
However, I found that the ignition module was placed just so that I
couldn't reach the two screws that hold it in place on the distributor. I
was told it might be necessary to remove the distributor altogether, but I
was also told that that is not necessary and I should be able to take the
distributor bolt and clamp off, rotate it, and remove the module when it
was in a better location.
So, I guess my question number one is: Has anyone changed the ignition
module on a similar model vehicle, and if so, how?
Question number two: I removed a bolt from the right, rear side of the
distributor, which I thought was the clamp I should have been able to
loosen and rotate it. However, I couldn't do that. The "clamp" appears to
have a U-shaped metal piece inserted into it, and I can't tell if I'm
supposed to be able to remove this metal piece or not... Or, even better,
how DO you remove (or rotate) the distributor?
And YES, I have marked everything I can up to this point to ensure the
proper reinstallation of the distributor if I need to remove and replace
it.
Thank you!
-Belle
Did a quick search at MSN autos. This may help
1991 Ford F150
Occasional problems on this vehicle are failures of the Fuel Pressure
Regulator, the Fuel Pump and the Exhaust Gas Recirculation (EGR) Valve.
Failure of the Fuel Pressure Regulator or the Fuel Pump may prevent the
vehicle from starting.
Edit: Sorry, jumped the gun. didn't see your actual question until already
posted.
first- check to see if you have spark. if not chances are it the ignition
mod. they are not hard to change. you should be able to turn the dist. to
be able to get to the bolts, it just might be siezed and you may need to
"knock" it free. just be carefull in doing so, i have broken one in the
past.
second- if you do have spark its a fuel issue (pump, clogged filter,
pressure reg.)
