Turn Signal Problem
Home  \  Repairs & Maintenance  \  Turn Signal Problem
I'm trying to figure out how to fix a turn signal that stays on no matter what, that is unless you disconnect the battery. That is the only way we have found to turn it off.
It has no response to the lever on the column and the left one works fine, the right side will just stay on and not respond to anything.
The Back and The Front are both lit up.
EDIT: 1994 Infiniti G20
posted by  ReagsX
has it got a seperate flasher unit for each side?.. a little box that turns the light on and off, could be that ones defective.(If you havent got a manual turn the one that works on and listen for the box "pinging" as it works the other may be alongside it,m probably under the dash board).. if it only has one then id look for a bad earth somewhere near the light.
posted by  sidecar_jon
More than likely you have a problem with the signal cam in the colum....
You have a fun job now :hi:
After awhile you might just be: :banghead:
