Won't start after 4 days of sitting
I have a '94 Honda Civic ex, 193k, 4cyl. 5 speed manual transmission.
Just got back into town after 4 days and my car won't start this morning.
The car sat for 4 days without running. The battery seems fine as the
engine seems to be cranking it just won't "ignite" for lack of a better
word.
Gas tank is full and no recent repairs have taken place.
The outside temp did not get below 50 degrees but we did get a ton of rain
while I was gone.
The car has run great so far. I'm the second owner and have put over 100k
on it and keep up with all the routine maintenance.
It is still early in the process, just trying to get a few ideas of where
to start. In my average car-related knowledge it seems as if the fuel is
just not getting where it needs to go.
thanks
Check if it's getting fuel...
Check for ignition...
Generally speaking, you can check if you have fuel by a valve, just like
one on a tire for air, on the fuel rail.
To check to spark just pull off a spark plug wire off a spark plug and hold
it about 1/2 inch from the block and have someone crank the engine and see
if you get a spark
In further expansion to this, I actually recommend a fuel pressure test
with the proper gauges and equipment. I am not sure what the spec fuel
pressure should be, perhaps someone else does.
You might also note that when checking for spark, you pull off a wire and
insert something metal to make contact with the connector down in there and
then hold it near the block, AWAY from any fuel leakage from the fuel
test,to make sure you have a spark. You will also want to make sure that
you are grounded and insulated from this wire when the engine is spun over
as there are many 1000's of volts passing through an automotive ignition
system. It is not many amps so it wont really injure you but it might
knock you down and into the middle of next week should you get zapped.
:thumbs:
