Car turns over but will not start
Heres the story:
My brother was changing the plugs in my 94 Mazda MX-6 LS v6 2.5L, he took
out one of the plug wires before changing any and forgot to replace it
before driving. He attempted to move it from one of our garages to the
other and the car stalled. He couldnt get it to restart, so he changed the
plugs and tried to see if it would start. We are getting fuel and spark
from atleast 2 of the 6 cylinders as i have checked them myself. Any help
or ideas would be greatly appreciated. Once again when i turn the key it
attempts to start and turns over but will not fire and start? What should I
try next?
Thanks
Jim
:2cents: Things to check......
1) Are the plugs gapped correctly?
2) Were all the plug wires installed correctly - proper firing order?
(more important than the first point)
Yes, all wires are in the proper order, as far as them being gapped correctly, it wouldnt turn over before we changed the plug, but were going to switch back to the old plugs this weekend and try that.
First we need to make up our mind, does it turn over or not? If it's not
turning over then plugs are the least of your worries.
I also wonder from reading your coded information what else we aren't being
told, like why the plugs were changed in the first place. Just for fun or
a wild ass guess that it might fix some existing problem.
Give us all the facts in a coherent manner, it makes it so much easier for
everyone involved.
OK heres the exact story.
The plugs were changed cause its at 100000 miles and we were doing all of
the servicing on it.
Before completely changing the plugs, my brother took off one of the wires
off for some unknown reason forgot to put it back on the plug and was going
to drive the car to our garage to change the plugs and some other stuff.
Halfway there at a stopsign the car stalled out, he tried to restart it, it
turns over, but wont start.(by turn over i mean it makes the noise of the
actual starting, not clicking or anything, the actual noise). But the car
will not start. So with the old plugs still in it wouldnt start. So we
decided to replace the plugs anyway. We replaced the plugs, and still it
wouldnt start. Ive checked all the wires, and they are in the correct
order, we are also getting fuel and spark in atleast 2 of the cylanders. My
father told me something like this had happened to him, and it was his
alarm on his jeep. So as a possibility i removed my alarm completely and
still no difference. The engine still turns and tries to start, but it does
not start. I hope this is clear enough.
Thanks ahead of time.
Jim
1. Have you performed a compression check and if so what are the
readings?
2. At what mileage was the timing belt last changed?
Not sure how to do, or even what a compression check is, but the timing belt was never changed, that i know of, thats actually on the list of things to do, Ill try that this weekend. Im at college right now, and the car is at home, so Ill be messing with it this weekend
If your brother moved the car in the condition it was, there is a very good
chance it could have back fired which is a good way to jump or break the
t-belt. Compound that with the possibility that the belt is 40k miles
overdue for being changed and you see where this might be going.
At any rate, that's not a diagnosis as much as it is something to think
about. Here is something else. How do you know you're getting fuel to the
cylinders?
We have pulled the wires and checked, the chamber where the plug goes was
completely dry, then while checking for spark we tried to start, you could
see a liquid and smell gas. Im goin home a day early ill take a look and
see if i can see any difference with the timing belt.
Ill post tommorow if i notice anything.
Thanks
Jim
We checked the compression and the timing belt today, I am almost positive it is the factory theft-deterrent system. Anyone with any other ideas would be appreciated. Im going to look around for a way to disable the theft override. Ill post tommorow night
Well i am absolutely stumped. We have compression, spark, getting fuel, the
plugs are gapped correctly, the timing belt is fine, and was actually
changed, it looks brand new, no cracking or even discoloration.
Im going to keep looking for a way to disable or remove the antitheft
deterrent and try that, if i dont have it running by monday, im going to
call a local garage and have them figure it out hopefully.
Any more thought will be appreciated. and thanks for all the help
anyway.
Thanks
Jim
I can't for the life of me understand why you're so insistent that your
problem lies in the anti-theft system. It works by shutting down your
ignition and fuel injection. According to you those are working so... You
do the math.
Furthermore, if you are so sure that's the problem, why are you asking for
help anyway. Perhaps you didn't read the sticky at the top of this forum,
or more importantly this section of it.
"4. The description. Please do not interpret what is going on with your
car, just give us an explicit, step by step description. We need to know
anything that might be a factor such as engine hot or cold, vehicle speed,
weather conditions, etc. There are too many possibilities to name them all
but you get the idea. Also, if you have already had the foresight to
retrieve computer codes (in instances were that is helpful) let us know
what they are. If you tell us you think it needs sparkplugs then your
answer will be put in sparkplugs. Keep in mind if you knew what was wrong
you probably wouldn’t be here asking for advice."
OK, sorry for keeping insisting that is the problem, Truthfully I have no
idea what the problem is, and vwhobo, you have been extremely helpful with
possible solutions and things to check. I dont know, Im honestly tapped out
of ideas, Thanks for the help.
Jim
lets look @ what we know first
We think we have spark (I would use a $6.00 calibrated ignition spark
tester and verify since we are also interested in making sure the ignition
system is delivering adequate voltage)
We think we have fuel (I would verify by checking fuel pressure with @ gage
attached to the test port - looking for 35-45 lbs on most cars key on
engine off)
We think the injectors are injecting fuel (could verify injector is
receiving signal from ECM to open using a noid light)
Things we don't know
1. Status of ECM touble codes (what trouble codes is the car throwing?)
2. Compression test results
3. engine timing being off (slipped or broken timing belt)
lets pull codes and other items above
hey this sounds like your camshaft sensor that your dealing with here. its a cheap part and only takes about an hour to change so your not lookin at too much $$$ to fix it if this is your problem but it sounds to me like it is!
I hope this guy is still looking for an answer after 4 yrs.
