'92 ford taurus owner with idle problem
Home  \  Repairs & Maintenance  \  '92 ford taurus owner with idle problem
hey everyone. im new here. my name is scott. i have a 92 ford taurus w/ a v6 3.0 liter and i just replaced the alternator w/ one from the junk yard ($35 vs $170 (and limited funds) and i also put on new cv boots. im trying to learn car repair, my father in law is teaching me the little he knows (brakes, alternators, etc.) and im teaching myself everything else. i wonder if its the idle speed sensor and ive heard i can measure it w/ my multimeter but how and what am i looking for? and also, can i draw diagnostic info w/ a key sequence that will flash the idiot lights. i thought my dad used to do that on some of the other cars. thank you.
-scott
posted by  kds_daddy
1. Huh?
2. Yes.
the engine is idling very fast and i would like to fix it so im not blowing so much gas and wearing on the engine so hard. ive heard it could be the idle speed control but how do i know and the rest is in the first post
posted by  kds_daddy
Yeah, that clarifies everything. Let me change my answer to this.
http://www.partsamerica.com/PartDetails.asp?SourceArea=SHOP&SourcePage=SEAR CHRESULTS&MfrCode=HAN&MfrPartNumber=36074&PartType=626&PTSet=A
ive already got the book thats where i found out about the idle speed sensor but i read something online about being able to put a multimeter across the sensor to read the voltage and determine if its bad. but i dont know where to put the meter or what i should get for a good/normal reading. and also. can i get some diagnostic info from the idiot lites by turning the key so many times or something? this stuff the book doesnt get into.
posted by  kds_daddy
Okay. You need to start spending just a little more time reading your manual or whatever you're getting your info from. There is no such thing as an idle speed sensor. How about an idle air control valve? Why are we on the harder to test, more expensive parts? Have you taken the time to look for a simple vacuum leak? I don't know any of these things because you're talking in codes expecting people to know what you're talking about. Try reading this first and then maybe starting over.
http://www.car-forums.com/talk/showthread.php?t=2200
so soap bubble all my vacum hoses and check for leaks or whats the best method to figure out whats wrong? where should i start. im just learning, sorry.
posted by  kds_daddy
This is my last attempt to save this thread. Go to the link below and read it carefully, then apply what you learn to this situation.
If you got a good DYI type auto book for the 92 Tarus such as Haynes, or Chiltons, ($15.00, Autozone, Advance, O'Reilly, etc or $5.00 if you can find one @ a used bookstore) you will find out several things about your Tarus. You will find out there are several things which could cause the car to idle fast such as some device such as the AC system sending a bad signal through the ECM to speed idle, bad throttle position sensor, bad coolant temperature sensor, bad IAC or idle air bypass valve. Use the instructions in the book to obtain the trouble codes in Key On Engine Off (KOEO) and Key On, Engine Running (KOER) conditions to provide a STARTING POINT for further trouble shooting.
Since some of theese parts can run between $50 and $100 each, suggest a little trouble shooting first.
