Taurus 97 - Lights on panel are crazy
Hello, I'm a mechanic in Brazil and I'm having hard trouble with a Taurus
97.
After a 2 hour trip, the low coolant and seat belt lights stay on and
sometimes the sound of the radio disapears but the radio stays on.What do I
have to check? What do I have to know about the circuit of control
panel?
I have OTC scanner updated to 2003 (is this a help?).
Any help will be very appreciated, thanks
Josmar
I seriously doubt that your Genisys will be of any help with your dilemma.
That being said it never hurts to pull codes and check the datastream, you
might get lucky.
From the brief description you gave, the first thing I would do is check
under the dash for loose grounds. If it takes two hours of driving for the
symptoms to surface you may be in an uphill battle trying to find the
problem. I've never seen this one before. Good luck.
