location of IAC on Focus spi engine
Can anyone tell me the location of the IAC on a Ford Focus spi?
Yes, it's attached to the throttle body. Of course your repair manual will tell you that.
Damn...I could've been 1-5 had I found the answer just a few minutes
earlier...Google searches work!!
I'm still 0-4 :cry:
yes it would tell me that, if I had a manual.
Only a fool does anything to his car beyond basic maintenance without a manual. If you're doing anything to the IAC you're well past the point of basic maintenance. If you have to ask where it is, you shouldn't be touching it at all.
Geez you are pissy. I wouldn't have to ask if I had the manual to tell me where it is. I am asking where it is located, not asking to be called a fool. If you don't want to tell me where it is, fine. Don't yell at me.
What trouble codes is the car throwing or what symptoms is the car exhibiting to require Idle Air Control valve replacement?
It's not getting replaced and I personally am not going to be cleaning it.
just curious - some of these little boogers run between $50 and $75
if I go to get a new one, it would probably end up costing 100+
If it's not getting replaced and you are not going to clean it, WHAT is your need to know ? By the way, the HOBO did not call you a fool, he was making a statement. But, if the shoe fits. :doh:
I've not bought anything from them but the boys on CrownVic Net reference
them a lot. https://fordparts.com/index.php I have found the prices
posted there are not too bad and in line with my neighborhood Auto Zone and
NAPA
The IAC valve for my Crown Vic is posted there @ a little over $50 +
shipping
