Temp. Gauge on 2000 Escort
Hi everyone! I'm hoping someone can point me in the right direction.
I have a 2000 Ford Escort ZX2, just over 100,000 miles. The temperature
indicator typically rides around the exact middle of the gauge, but last
night, it started creeping up to around 3/4 of the way to hot, which
concerns me.
It doesn't seem to matter if I'm idle at a light or driving on the freeway,
it will randomly go between 3/4 to hot and exactly in the middle, creeping
up and down.
I'm INCREDIBLY broke at the moment, but I can't live without my car. Any
ideas for easy, cheap ways to determine what could be causing this problem?
Have you checked your thermostat?
That was my first thought as well. As the problem just started last night,
I haven't yet.
Can auto parts stores check things like that for free?
Don't jump the gun. If it isn't climbing dangerously high, whether in traffic or driving normally, you're fan is cutting in as it should do. If it's unusual for you car, have the thermostat checked by all means!
Nah...you don't need to go to any shop. It's simple.
http://www.ehow.com/how_7683_tell-cars-thermostat.html
That little article should help.
My coolant was fairly low, so I filled it up and drove around for a bit to
let it run through. After about 10 minutes of driving around with the
heater on (which was working noticeably better, but eventually started
conking out again), the car wouldn't stop with the 3/4 hot bit.
I went back to the auto parts store to look into the cost of a thermostat,
but decided to wait a day so I can research better how to replace it on my
own. Anyone know of a good place for diagrams? :) I know eventually that
I'll need to invest in a Haynes or Chiltons manual, I'm just broke enough
to where the $20 for one would hurt.
Thanks again for all your help! :)
