Spilled Soda on Gears
Guys, I posted this on another car forum, but their members were idiots, so
I'm hoping you guys can help me out..
I have a 95 Altima, and I went to Wendy's today and ordered a regular sized
meal, but they charged me for large and gave me a large meal. So, I decided
to just take it b/c I was too lazy to go back and argue with them. I put
the HUGE cup on my cupholder (it doesnt fit, barely) and I drive forward,
and the soda tips BACK and all this Dr Pepper spills onto my gear box (? is
that the right term? its the thing i shift back and forth to go from park
to drive, reverse, etc.). Is this bad? Did any soda spill inside and will
it screw the shifting mechanism?
------------------^^^ (the above was posted last Thursday)
The following happened yesterday:
I started my car today and the gear shifting thing, it was so HARD to move!
But like after the car started running, it was fine. My mom spilled soda on
the gear a long time ago, and she said the same thing happened to her. When
the car runs for some time, the sugar melts and the gears move again. When
the car is idle or when you're first starting it, the sugar has been
crystallized and the gears are hard to move.
Is there any way I can clean this by myself?
Here's a diagram of my interior:
Ok, heres my interior:
http://www.autonav2000.com/images/ScrapBook/Nissan_95_Altima_2.jpg (without
hte little GPS thing)
If you look at the gear shift thing, theres a little black covering at the
bottom...
http://i3.tinypic.com/449gbpz.jpg
(i enlarged the figure)
Where the bluish thing is pointing, that little black strip, that whole
gear strip got flooded with soda.
Please help/
You're gearbox is under your hood, not under the shifter. The sugar is just making the lever itself sticky. Keep using it and it will break free and work fine again.
Wow I can't believe it's someone posting who isn't like some troll.
Welcome to cf?
Yes, yes, I meant the shifter, my bad. Are you sure if I just leave it, it will be fine in a while? Is there some way I should clean it or should I just let it go?
You mean to say that other Forums have idiots, too? :laughing:
Yes, but I dont see how that is relevant. Can someone else provide me with some good course of action?
It's called having a sense of humour.....As for your problem, you've been helped already. What do you want? us to tell you of a super-dupa cleaning agent that'll rid of your problem? Just heed the advice you've already been given, that should be enough! :banghead:
So you can basically guaranttee mee that if I Just leave it alone, it will fix itself?
I can't see the car, but given the info that you suplied, yes, it should be ok!
Well, you can see the interior and I've showed you where the soda flooded. So, how long do you suspect it will take till the sugar like melts away permanently or w/e?
It'll just 'wear' away soon enough. I spilled a little tiny bit of beer on my laptop a couple of weels ago and that worried me (what with all the electrics etc!), but even that survived, so your car should be fine.
If I didn't know any better I'd say spoken like you are some type of redneck! :orglaugh:
In my best accent....:laughing: ....
i hate people like you,no it wont be ok itll work its way into "R" while your driving and veer off and kill a family in a minivan, you better go get that fixed so you dont cause any accidents
I just checked because you said you asked on another forum, and I can't see how the members were idiots...They gave you the exact same answer as the members of this forum...
Ok what do you honestly want me to say? That you're dumb too??
*sighs*
That forum said it was FINE. It's not FINE. I have to exert pressure to
move the damn gear shifter. Does that sound like fine to you?
Yeah, they gave you the same answer...
It does sound fine. If you take everything off to clean the spill, it'll
take a while and you still won't be able to get rid of all of it. Just
relax, it'll clear up.
I wonder if some contact spray would help loosen it up a bit?
You seem to think that everybody is in some way obliged to help you. You
asked us for advice, and we supplied it. As did the other Forum! :banghead:
And a bit ofspray will always help, as Talonchik suggested.....:thumbs:
Your car shouldn't break, but I hate sticky-icky in my interior. I would
remove the cover that the soda spilled on and clean it from the inside.
I strongly suggest you think before you post insults about members in
future, otherwise yet another 'What' account will be banned!
If you are really worried, you could remove the plastic, and spray some
brake clean on the linkage. If you can't see the linkage, you may need to
get under the car.
I don't know what it would take to remove the plastic cover. Most likely
it pops off, but it may have screws...
NOW KIDS.....what has this taught us all....DONT DRINK AND DRIVE!!!!:banghead:
I am sure nothing bad will happen it will prob. just be a little sticky for a while :smoke:
yea your screwed, spilled soda on the gearshifter usually f's up the transmission. get ready for a rebuild:thumbs:
u may wanna try n steem clean it cos i spilt some stoof on my car 1'ce n well it stayed stiff till we gave it back (company car) just try n clean what u can out
Hang on a minute....if I read that correctly (it was quite difficult to read...), you are suggesting he steam cleans it? even though it's inside the car, and would controdict his problem in the first place? I mean, if he did ever come back here and grace us with his presence, I'm not sure he'd want to make the gear lever and surrounding areas soaking wet, as this could cause the problems that his spilled drink didn't....(Water and electrics tend not to go well together....):ohcrap:
Fixed.
Also, the gear shifter will constantly be moving, if you rubbed the area
that you spilled, it would eventually be fixed.
Basically, that lever consists of just metal line in a plastic sheath that
goes to the transmission, and a lever mechanism.
Soda's going to get into the mechanical linkage for sure. Won't cause any
problems with the lever mechanism until it freezes one night. It won't
shift into any other gear on you and if it does, the car will probably stop
really fast.
If it gets into the metal line, which is unlikely since they are often
sealed against getting crap in there in the first place to inhibit rust,
then you've got a problem since it won't tension correctly and has the
potential to screw with the trans.
I'd personally go in there and clean it. Rubbing alcohol is the best stuff
for cleaning up that sort of mess since it dissolves everything. Avoid
brake cleaner; it'll dissolve the plastic as well.
Don't spill soda in your car!
Oh yeah, and don't look for garountee's from people on mechanical forums.
If you come here for advice, great. If you're coming here for emotional or
mental support and can't differentiate between a troll and someone who's
trying to give you good advice, then you should be flamed into the stoneage
until you begin to realize that lesson.
if u steem clean it most of water eveporates so ur ok
You're a f*cking idiot. Go climb back under your rock. :banghead:
Well it is a gear stick. :wink2:
Take the console off and give what's left a good clean.
I f*ckin' said this weeks ago Wally. Don't start this sh*t with me.
... but I have now posted the solution and that carries much more weight.
Pour the purest rubbing alchohol on it that you can find. 91% is what I used for this problem (I think you can get 100% which is best). It works on radios and electronics too because the alchohol is not conductive. I have even heard that it works on cell phones. The only problem is that you have to air it out because the smell of the alchohol is very strong, but it will wash away soda and other gunk for good...
I couldn't resist... :laughing:
-Matt
I just did the same thing today and was freaking out a bit at how sticky the stick is. Thank you!!
Drain Cleaner: The most common type are liquid caustic solutions containing
sodium hypochlorite NaClO(bleach), sodium hydroxide (lye), or potassium
hydroxide in concentrations up to 40 percent. These are used to dissolve
grease and hair clogs.
As you can see above "These are used to dissolve grease and hair clogs.".
Your main problem is the hair clogs. Just get some Draino and problem is
fixed.
NOTE: I would not recommend pouring this stuff into your shifter.
