1995 Cavalier
Hi guys I am looking for advice in replacing the head gasket for a 2.2
litre Manual Transmission 1995 Cavalier. Below is where I am now!
- It's a project. The biggest I have undertaken to date. I bought the car
for 300 bucks and drove it home it was diagnosed at a garage before I
bought it.
- I have the haynes manual and have reviewed the procedure
- I will be buying my new torque wrench on the day I have the all clear to
take over the garage for as long as it takes.
- Is there anything else I should be looking for when I pick up the gasket
kit and head bolts.
- Are the there any FYI's that I should consider also are there any things
in particular I should be expecting? i.e. When you remove x then y will pop
across the room.
Any help would be appreciated!!
Thanks
Hopefully I am not just taking a log here. I'm expecting that I may need advice as the event transpires. Things have moved faster than I thought I now have the garage for the duration of my adventure. I have the gasket kit and the bolts and a brand new torque wrench. Hopefully I will get some actual work done during this week or so.
My advice to you is to make special note of every wire and hose that you
take off so you'll know exactly where it goes. Be careful and take your
time. Dont hesitate to ask questions. If possible I'd even advise you to
take pictures of everything before you take it down, and as you take things
apart, just incase you get confused when trying to remember how everything
went when you put it all back together.
It's not that big of a job, but mistakes can be made for first timers. But
not if you go by proceedure and pay attention, and ask questions.
Good luck.:thumbs:
i would look here http://www.j-body.org/ for advice
Right on guys! Thanks. I'll take the picture advice........it seems like a
no-brainer now but I never thought of it! I just took off the cover I was
gonna drain all the fluids i.e. oil and anti-freeze. I am sure about the
antifreeze. Iis the oil a good idea too?? I gave up though as it's late and
I am stuck at draining the rad. I went looking for the drain plug and all I
can find is an empty bolt hole on the bottom of the drivers side of the rad
(Canada) What's up with that?? Should there the something there? If so is
it the drain plug? If not what is it? If so I guess that explains any hot
running scenerios the girl I bought the car from might of had??? What about
the head gasket diagnosis the mechanic gave her?? Ya think he'd be just
guessing based on coolant loss or worse just making work??? I hope these
aren't all dumbass questions??
Weather the gasket needs replaceing now or not I'm doin it though.
You're in luck. The 2.2 is one of the easiest cylinder heads around to
R&R. here are a couple of tips from someone who has done SEVERAL (possibly
over 100) as opposed to some of the other "advisors" who most likely have
done none.
1. I'm sure your manual probably says something to the effect of "remove
and tag vacuum hoses" etc. What it may not say is to pay special
attention to the EVAP canister purge hose under the intake. Not so easy to
see, easy to damage.
2. Again, the manual probably says to remove the intake and exhaust
manifolds from the head. Don't do it. Leave them attached and remove them
AFTER the head is out of the car. Do the same thing on assembly.
3. Make sure you perform a good inspection on the deck for any damage and
get the head professionally checked for straightness and resurfaced.
4. Make sure your head bolts and holes are properly prepped and FOLLOW THE
TORQUE SEQUENCE EXACTLY. After you've reached the torque to yield portion
there is no going back. If you have to remove the bolts for any reason,
it's time to shell out for a new set.
5. Make extra sure you bleed the cooling system properly so you don't have
another overheat and blown head gasket.
Have fun, good luck.
P.S. Have you determined what caused the original head gasket to let go?
If not, you need to do so prior to start up.
Thanks vwhobo
No is the answer to determining what caused the initial gasket crack. Any
suggestions? I will take you advice though in regards to the head removal.
Thanks again!
Well., ideally you determine what the root cause was BEFORE teardown, but
it seems we're past that point, so...
First we have to determine if the old head gasket gave up due to
overheating, improper assembly or possibly old age. You can substantially
figure out the last two simply by knowing the mileage on the engine and the
repair/maintenance history of the vehicle. You just bought it so you may
not know either.
That being said, a set of experienced eyes looking at the engine components
as they come apart can give you volumes of information. Are there
fasteners missing and hose or electrical connections cobbled together?
Those (and others) would be a sign of sloppy workmanship that if the heads
had beed off previously could most certainly lead to a blown head
gasket.
On the other hand, does the oil smell burnt and is it caked inside the top
of the cylinder head? What do the coolant and the cooling passages in the
block look like? Has the wax pellet in the thermostat literally exploded
from heat? Is there even a t-stat installed? These would be signs of an
overheat condition and in the case of the last one, someone misguidedly
attemting to "rig" the engine so it won't.
Basically you have your homework cut out for you. At a minimum, I
recommend replacing the t-stat and flushing the entire cooling system
before you start the engine and then bleed it a fast as you can after
start-up and watch the temp guage and troubleshoot it from there.
P.S. What did the "mechanic" who diagnosed the blown head gasket say
caused it?
P.P.S. Before I hit submit, I thought of something you may be unaware of.
If the engine was overheated, they are sometimes overheated to the point
that the pistons scuff and the rings lose their tension. If that happens,
the engine will never run correcty if it'll run at all until it's been
re-ringed at a minimum. It'll also smoke (burn oil) like a chimney.
Man am I glad I posted on this site. Thanks very much for your
input/advice! Here we go:
I would assume old age tied in with useage is the cause as the car has
305,000K on it or 190,000 miles. However it was 100% lady driven and she
didn't come across as the lead footed type (just a guess though).
I don't think the head has ever been removed as everything is in an
untouched condition. Actually the only signs of any real under the hood
work is a new alternator and battery along witha new set of plugs...but not
wires rotor or distrubutor.
As for the oil no it doesn't smell and it actually looks good (on the top
side that is, as I only have the cover off at this point) there is no
"caking" and it actually is kinda golden in color. I'll have to get back to
on the t-stat when I get that far. I have company in town on the weekend so
no tinkering for me for at least a week. (Maybe)
I have no idea what the mechanic might have suggested for a
cause......dammit I never ask enough questions. But I bought the car as
learning experience and already I've learned one or 2 things.
As for the piston rings I think I am good there as I have run the car a
number of times before I stuck her in the garage anthere isn't ANY blue
smoke comming from it. Can I inspect them some way all the same when I get
the head off??
Also I don't know if you saw it but I posted awhile back saying that I
sized up the whole rad and could not find the drain plug I did however find
an empty bolt hole???? Is that normal or is that where my drain plug should
be. I am thinking weird things because of that.......maybe you can set me
straight. Also should I drain the oil before I take the head off??
Thanks so much for your advice I am bound to have many more questions so
I'll do my best to not have you get fed up with me. Thanks again.
Okay, I guess I should have asked this to begin with and forgot, but your
last post reminded me. Old age you know. If you drove the car home and
you have run it a number of times, what are the symptoms that leads one to
believe it has a blown head gasket? Engines may and do run with a blown
head gasket, but they seldom run very well, especially a four cylinder.
Let's make sure this is what you need to do to fix the car.
Has a compression check or leakdown check been accomplished? Is there oil
in the coolant or coolant in the oil? Excessive cooling system pressure?
White smoke (steam) from the exhaust? Unexplained coolant loss?
Combustion gasses in the cooling system? How far is it from where you
bought it to where you live? Unless it's less than a mile, one or more
symptoms should have surfaced. Make sure you're fixing the right thing.
About 20% of the cars I see diagnosed with blown heads gaskets don't have
blown head gaskets. And the more I read in this thread, the more I think
your car may be in the 20%.
Okay I managed to track down the mechanic. He says it was visible as you
can see the coolant leaking out of the back of the engine. I will "TRY" to
verify this this evening but as you've discovered by now I may not notice
even it is obvious. But you can smell coolant mixed with oil now that I
think of it!
Thanks again
1. Many things could cause a leak on the back of the engine, a head gasket
is but one of them.
2. I don't think so. If there's enough coolant in the engine oil to smell
it, there's also enough to make it milky. You said previously that the oil
is a golden color. See the disparity?
3. Four words. Cooling system pressure tester. If it's an external leak,
and it could well be, this is the way to pinpoint it.
Side note. If the engine has as many miles as you say and the head hasn't
been worked previously, you need to budget for a basic valve job as well,
or at least disassembly and inspection by a competent machinist.
I do like to read that someone is having a go at the actual engine rather
than connecting shiny peripheral stuff and becoming a mechanical expert.
Regardless of whether the gasket is knackered or not, it would be a grand
adventure to whip the head off and see in real life what's there.
You have a good mentor in VWHobo, so the only advice I will offer at this
stage is to make sure you soak any residual oil/water from the head bolt
holes in the block (use cotton buds if necessary) and use thread
conditioner on the head bolts.
How do I do a cooling system pressure test?? Can I do it with out spending
a big pile of dough on the neccessary tools? Or do I need to bring it to a
mechanic?
As curious as I am about my ability to do a gasket change I don't wanna do
it for naught. As for the smell ya I see your point and I am not gonna
torment you with it any longer until I get to the root..........I was gonna
say of the problem but that is the problem The car runs fine I couldn't
believe it when I drove her. I mean I test drove on the highway for at
least 5 miles the car runs perfectly the head gasket idea only came from
what the mechanic told this lady. Maybe I should just let it be? As for the
mileage oh ya she has that many 305,000km. What about the valve job? What's
involved? Maybe I can change the scope of my project/hobby. :thumbs:
And Thanks Wally!!
Compression test, leakdown test and cooling system test can easily be
carried out by a mechanical workshop and should'nt be costly.
I'm not familiar with the particular engine you have, but the underside of
your oil cap will probably have white cream if you have water escaping into
oil side. A weeping gasket may just be a failure of the surface beading and
although it will tend to rot in that area, there may well be many more
miles left before you need to change it.
The leak that is apparently coming from the gasket may well be tracking
from somewhere else (e.g. intake manifold gasket, pin holed hose/pipe, etc)
What Wally said... :wink2: I don't know what's available up there, but in
the States you can get free loaner tools from the bigger retail parts
stores. Maybe Canadian Tire does that too. None of the three tests are
hard to do, but the leakdown does require the use of shop air
(compressor).
If the head ends up coming off, all the valve job consists of is removing
the valves, resurfacing the valve faces and valve seats, checking the
springs for proper seating pressure/shimming if required and replacing the
stem seals. While it's in the machine shop, it's money well spent to have
it (the head) cleaned and checked for straightness and machined if
neccesary.
P.S. to Wally. Why do you have to go and call me a "mentor". I've just
gotten used to you calling me "mental". :hi:
Some vehicle owners that only make small trips and dont ever get the motor to operating temps usually have that nice milky coating on the underside of the oil cap from condensation that never gets burnt off, If im wrong someone should let me know:thumbs:
Tanks for all the input guys! Especially you vwhobo. I WILL get those tests done asap and make a decision from there! I am still gonna do the gasket and screw it the valves to while I am at it! I'll post again when I gets some garage time going............thanks again guys thanks alot!!
Staus Report Jan 21 2007
I now have the head cover off and the rocker arms and push rodds
removed......bagged tagged and detailed. I know the could have waited but
curiosity gets me sometimes.
I have the radiator drained and flushed.....(with little mess.... booo
yeaaaaa)
I have the alternator removed which leads me to problem one. Question and
info below. I have some pictures of the pulleys on the front of the engine
illustrating the lack of the described tensioner for the 2.2 engine I hope
to attach but I seem to not be able to do that. Nope can't. I'll try to
make them smaller soon and then do it.
1) Where is the tensioner on this car??
-------It is not where the book says. 100% I looked on the net and found a
picture of the 2.2 and a full front look at the engine and that tensioner
is not on my car . I cut the serpentine belt so now it will be an issue on
rebuild but any suggestions would be greatly appreciated.
2) I was told I can purchase a replacement head from an auto store. Is this
true? Any input? How much would it run me?
Any I'll keep posting as I progress. Advice is welcome.
Staus Report Jan 28 2007
I now have the head cover off and the power steering pump removed. What a
b*tch considering I have really large hands and there's not much space
around here. It looks like the there is a leak on the lower end of the
upper hose. I haven't really inspected it yet and as I am learning as I go
I have no idea weather I can repair it or or if I should replace the whole
thing?
As for the pump itself It worked before I took it off so I see no need to
replace it. Any ideas from anyone on suggested maintenance procedures while
it is off? i.e. cleaning flushing etc.
I also removed the plugs while I was at it today too. The plugs were
supposed to be new. But where very very full of carbon. Also on plug either
was put in crossed treaded or became that way when I removed it. I was
worried the plug would break but luckily It did not and I put tremendous
amount of force on it. However now the treading on the inside is damaged.
Any suggestions???
Anyhow I'll keep posting as I progress. Advice is welcome.
1. Your power steering has two hoses... A pressure and a return. The
only repair for a leak, depending on where it is and on which hose, it
tightening, replacing the o-ring or replacement.
2. As you have the pump off, you could dump out the reservoir and refill
it with fresh fluid. If you're really motivated, you can do a basic system
flush but I won't explain how to here.
3. Aluminum heads, crossed threaded plugs, what a shocker. Happens to
hammer mechanics all the time. It's also an easy fix either for you or the
machine shop. If you want to DIY, here ya go;
http://www.thetoolwarehouse.net/shop/HEL-5334-14.html
Ok Thanks! I will likely have the the plug threading done when I get the head inspected......That's a relief. I actually have the Power steering pump drained. I have the steps for bleeding the system on reinstall. I'll just clean it up a bit unless there is something I should run through it? As for the leak I will attach pics this evening when I get home and show you. I assume it's the pressure hose as its the one with the metal fitting that you shove into the pump as opposed to the rubber hose that was clamped onto a fitting. The leak is on the opposite end of the hose so I may size that up and just replace the whole thing to be safe. Thanks again I'll post a couple pics this eve. and be back with another report next week. So what are the betting odds on the car ever running again? My moneys on it running.......but I'm known to be a cocky SOB even when I'm losing!
Pics as promised.
EVAP canister purge hose under the intake. Not so easy to see, easy to
damage.
Ok so I tried to remove the aforementioned hose. I have no idea how to get
it off. Any help?
spin slighlty as you pull vacuum line off nipple or get a little pick and work it around slightly
Ok but what do you use to loosen it? I can't fit any of my wrenches in
there. I was looking for a suggestion on what to use. I may undo the motor
mounts when I go at it again and try to pull the engine forward to get at
it........does that sound like a good/bad idea??
Thanks
No wrench or special tool needed. Unless something has changed since the
last of the zillion or so of those that I've done, all you have to do is
remove a rubber hose as at least one person has previously mentioned.
Directions to remove EVAP cannister purge hose.
1. Twist.
2. Pull.
3. Cut if necessary.
4. Replace as required.
Hey Everybody!
Ok so I have the upper intake bolts all removed. Along with hoses, elec.
connections etc etc. And it's not even budging. I know why I think though.
It's the hose that I have shown in my pictures. I am at a loss as how I can
loosen it from the place where it goes into the lower manifold. None of the
tools I have will let me even fit in there. Any suggestions? So since I was
defeated there I moved to the other end of the hose and loosened that nut
thinking if I removed that end of the hose I may just be able to twist the
hose to loosen the top part. Good/Bad idea? After I loosened the nut I
never even pulled the hose free as I have not drained the oil yet and
decided that if I pull that hose oil would start running out. Would it?
Well that's where it ends today. Any input is always appreciated.
Status Report Feb 18 2007
Ok so I finally got the EGR pipe off and figured out what it was while I
was at it. I had to take a hack saw to one of my adjustable wrenches but it
worked. I now have the upper intake removed as well. I am gonna take VW's
advice and not remove the other manifolds. Until the head comes
off.........now I'm getting nervous. I got stuck with the Fuel pressure
regulator. I assume it's the right idea to detach it from the lower intake
manifold.........however the hex bolt that holds it in is too close to the
brake resevoir for me to get at with my socket hex keys........I guess I'll
go buy the right size in the old fashioned key type if I can find it.
That's where I stand now. O also attached a few pics of what the top of the
lower manifold looks like for any input.....it looks pretty nasty to me but
the car does have over 300k on it. Opinions are very welcome.
Status Report and questions Feb 25, 2007
Well I was confident that today was going to be the day that the cylinder
head came off. I just never thought that I would split one of my lifetime
warranty master craft deep sockets. Which leads to question number one. Is
it odd that one of the head bolts is next to impossible to turn? Most, as I
expected are easy to turn as they are torqued as per spec. Two though were
very hard. I got one after just about pushing the car off the jackstands.
The second however actually split my deep socket. So now I have to go get a
new 15mm.
VWHOBO I respect your advice but had to go against it in regards to the
intake manifold. I took it off first as I wasn't sure I had all the hose
and connections disconnected and the olny way I could see for sure was to
take it off. I will leave the exhaust on though I also see why it's better
to put them back on before I put the head back. Which leads to question
two. There is a gap betwen the flanges of my exhaust mainfold and the
exhaust pipe. I have attached a pic. Is this normal? I also have attached a
couple more pics for review. Feedback is appreciated. I am actually
disappointed that there is as little feedback as there is.
I am having picture problems so I will post them tomorrow.
Ok so I went and got a new 15mm deep socket. Sure enough it worked and the bolt came out..........I then moved to the next one and my new g*dd@mn socket split..........I went back to crappy tire and exchanged it again..........went home (I have used much WD-40 before some asks) tapped it with a hammer for good luck put the socket on and twisted..........F*CK it split again.........Not to be defeated I procceded back to crappy tire for a new socket (luckily theses things are lifetime warranty) at which time I also bought a blow torch to add a little heat to my bolt (Is this a bad idea?) I never added much though as the flame used to suck down the spark plug chambers and scare me a little. Anyhow I put the socket on the bolt twisted and........Holy MFing antichrist g*dd@mn etc etc. it split again:banghead: . Can anyone offer advice here?? Maybe I am gonna answer my on question but I have noticed tougher looking black sockets on the shelves that I think I will try, if inspection of them suggests they may be stronger than my sockets. No I haven't inspected them yet as obviously I am a slow learner. Anyhow I may not get another chance to try this till the weekend as stealing family time for my hobby is frowned upon by my wife.......however my pride might walk all over my morals and I may make another attempt this eve. Any input is appreciated!! :doh:
1. A black socket is most likely an impact socket. Impact sockets are
supposed to have thicker walls, have a better heat treat and be stronger.
Notice the key word, supposed. I know nothing about the brand of tool
you're using so that may not be the case. I've seen places that sell
regular chrome and "impact" sockets that are exactly the same tool with the
exception of finish. More importantly, you want to make sure you're using
a 6-point socket and not a 12-point as they are usually stronger. All
impact sockets are 6-point unless they're special purpose. Additionally,
you'll find a shallow socket is almost always stronger than a deep
socket.
2. Not much point heating up a head bolt. You can't really get it hot
where it needs to be heated most, in the thread area, plus heating it may
actually make it harder to get out. Expansion and all. Try giving it a
few good sharp raps with a BFH and something long enough to reach the head.
An old garbage extension will do the job. Just don't dick up the head so
the socket doesn't fit.
Thanks VW
Ya I was actually just doin some research and the black ones are impact
sockets and I will purchase one tonight. As for my current socket I have it
in my pocket so I pulled it out for a look and wouldn't ya know
it.........it's a 6 point.....as for the shallow socket it's a no go as
it's the bolts that you need the deep socket for that are the
problem.......so I'll give up on those ones. I just cannot believe the
break so easily. Thanks again.
Tear down done!!
Yup It's done. I got the head off. I bought the impact socket yesterday and
it took the pressure. I have attached a picture of the the cylinders for a
look it looks real dirty with what I assume is carbon formed into chunks on
top. Anyone have advice here?? Also I have one other question. I have had a
couple good wrestles with a certain type of hose clamp. (Pic attached) Is
there a special tool or method of removing these? I obviously have ruined
the ones that I removed. What do I call them when I go the buy them? Just
in case it's not answered in the removal question how do I put them on?
Again is there a method or tool?? So I figure now I won't need anymore info
from you losers as reassembly is bound to be a breeze. :fu:
PLEASE, note the sarcasm above. I appreciate all the info.......almost 100%
of which came from the old contrary guy. Thanks alot.......I am sure you
know that I will be hounding you again.
1. You can clean out some of the funk from the top of your engine, but
don't kill yourself trying. Just make sure that anything you scrape off
the top of the cylinders is cleaned out before putting the head back on. A
nice thick layer of Vaseline on top of the piston catches it well and is
easy to clean out with a paper towel.
2. They are called constant tension clamps. If you really want to
purchase the correct tool for them I can lead you the right direction,
but... As you have to replace the damaged clamps anyway, just go ahead and
get regular worm drive hose clamps. Cost less, no special tool, new and
shiney.
3. Make sure the deck surface on the block is spotless before you install
the head. Also beg, borrow or steal a thread chaser to clean up the head
bolt holes. If you send me some Molsons, I'll show you how to make a
serviceable one for free.
4. Screw you buddy. :wink2:
Thanks again!
As for the Molsons.....as a fellow fan I think you'd really like the new
beer I discovered here in Alberta it's called Kokanee and it is excellent.
However the corss border tansfer of liquids is a sensitive subject theses
days........you'll just have to come over to this side :laughing:
Is it good enough I wonder to clean up the old bolts and then use them like
a tap and run them through?
I may actually have more questions in this regard I never even had a good
chance to inspect the head yet. Hopefully on the weekend.
Again if you get the chance try the Kokanee.
Ok. So I am confused as to what I should do in regards to my head. I have called one shop and his quotes were $250 for a surface machining and valve job. Or $400 for a refurbished. So tomorrow I am gonna call the other 2 shops here in Calgary and see the quotes. I am also going to call a dealership and price a new one. However my other option is to go to the local pick and pull and find a quality looking head and replace mine with that. Is this a reasonable option? I was there today and saw a few good looking heads. So I am considering this. Just looking for info here. Any is appreciated.
Update March 24 2007
Ok I need some help. I have noticed though that Vwhobo is not around
lately. I even tried pissing off Cliffy to see if was checking in. Anyhow I
need advice and would appreciate any creative suggestions. I have the
entire reassembly done but have a huge problem there is antifreeze leaking
at a pretty good rate. I cannot see where it’s coming from although it
looks like it could be the housing that the EGR valve and the thermostat
housing are bolted to. Is this possible? I have looked at all the hoses and
it doesn’t seem to be those. I started the car (It did start yea) but
only ran it for a second as the antifreeze was leaking of course but it
does run out ALOT faster when the car is started. So is there anything
anyone can offer here? PLEASE!!!!:banghead:
Ok so after I put everything together (months ago) I ended up with a leak. Life and defeatism set in and the car sat for a few months. So after getting sick of looking at it I removed the aforementioned housing and replaced the gaskets again. This time I put a coating on it........oops. So that ended my leak. Now the car is done. I sold it yesterday for a little less than I wanted for it. I never lost any money on it and the guy who bought it needed a break (or so it seemed) so everybody wins. Anyhow I would like to thank all those who helped or offered advice. Of course I especially want to thank the Hobo. Thanks alot I appreciate it. I hope your current business endeavor is doing well. I sure hope your around for my next project as I think I now have enough confidence to take on something that will mean something to me..............like an old truck or a 69 Charger..........oh the potential
