Corrosion Spots
Hi!
What is the best possible procedure to remove corrosion spots and then make
sure that they don't come back in six months?
Thanks
Alex
I'm not sure the best possible way. But I'm assuming you are talking about
rust on the body, and not like corrosion on the battery terminals?
I'm not sure the best way, b/c if you sand it down you will have to repaint
that spot and idk wut that will do to the paint around it, or the way it
looks.
I'm not a body/paint guy, so I'm sure someone on here is.
Hi!
Thanks for answering, yep, the corrosion is on the body near the
windshield.
Too small to go to the dealer because they will charge an arm and a leg and
serious enough to get it done soon, otherwise, the corrosion will become
unmanageable
Alex
Yeah, around a window would be a good place to stop the rust. I'm not too sure, but my brother is good with this kind of stuff. He worked part time for a custom paint shop (mainly choppers) for a while. I'll ask him what he would do in the next few days and let you know.
H!
How do the people in the restoration business refurbish and remove
corrosion?
There must be industrial chemicals available for corrosion removal and
inhibition? Is it better to sand or use chemicals to remove corrosion?
So many questions
Thanks
Alex
If you're in the business of restoring cars, you probably would want to do
it the right way, which would be to replace the whole panel. I've seen
people just cut out the piece of metal that was rusted and weld in a new
piece. Thats a lot of work though, to make everything look smooth with a
new piece of metal on there.
I've never heard of using chemicals to remove rust, so maybe you're talking
about some other kind of corrosion. The cheap way is to take a grinder and
grind off the rust, and then just repaint that spot. That will look better
than it did before, but still not very good overall.
I'm certainly no body expert, but I don't see anyone else who's very
knowledgable chiming in. My advice: if you want a real good job done,
bring it to the body shop. People can do a nice job themselves if they are
experienced, but you don't seem to know much more than me about the
subject.
If you sanded it down, primed it, and used some touch up paint to cover it, it will probably look different than your original color still. It could mess up your paint around it too. It would be best to take it to a body shop, especially since it is right around your window. You don't want to have a leak.
1815Hi!
I have attached a picture referencing the fact that this product removes
corrosion from cars allowing you to paint afterwards.
Alex
Hi to Everyone!
Am I whistling up the wrong tree by posting the corrosion removing chemical
or am I behind the times and this is a normal procedure
Alex
