Automatic To Manual Conversion
Home  \  Repairs & Maintenance  \  Automatic To Manual Conversion
Hi I have a 96 Accord LX Its automatic right now.Later on Im planning on doing a engine swap to it with a H22a engine.The thing that I wanna know is how can I check if im gonna have to do adjustment like drilling holes to change the transmission to manual or If I even gotta do all that.If its gonna be a hassle I would like to know before I get myself into it.So what do u fellas think?
posted by  Wzs99
I'd recomend clicking Here (http://www.car-forums.com/talk/forumdisplay.php?f=25) first as you're more likely to get help that way...and after you've done that, I'll tell you that it's both complicated and costly :thumbs:
posted by  Cliffy
Not only are you looking @ the tranny work but you may need to do some Engine Management System work too. A different ECM or ECM calibration is likely to be required for a manual than an automatic due to the automatic tranny diagnostic functions provided by OBD2 systems - make sure all of this is covered before you start swapping - In some states and communities, an engine/tranny/ecm mismatch could cause the car to fail emmissions inspection by throwing trouble codes and setting the check engine light.
