Coolant Leak...
Home  \  Repairs & Maintenance  \  Coolant Leak...
i have a coolant leak on my 95 Regal. I took it somewhere to get looked at and he said that it was leaking from a plastic plug around the alternator or water pump. What plug is he talking about and is this right? It leaks when car is running and shutoff. It is not the radiator drain plug. thanks
posted by  JDay
He is talking about the weep hole in the water pump. The internal seal has outlived its purpose and can't be repaired by you. The leaking is the last warning you will get, before the internals of the pump completly stops working and deposits a bunch of crap into your cooling system. Needs replaced NOW! :2cents:
posted by  lectroid
