rough idle then cuts out/code 54
thx for the time to read my problem.84 Olds cutlass supreme 307 87,000
miles the problem started when i was on the expressway in heavy stop and go
traffic, while i was stopped the car idled real low the check engine light
came on and i had to two foot it all the way home. For the past 2 months my
idle has been so rough that i dont even get a chance to put it in gear
before it cuts out. i get black smoke out of both tailpipes & soot out of
the drivers side tailpipe i have no cats. I got an error code of 54 which
is the m/c solenoid. i replaced the solenoid myself. drove the car around
the block, it died out, i got it started and went home to check for codes i
got same code of 54, oh btw i disconnected battery for 5 mins also. things
i have changed, spark plugs,wires,coil,cap & rotor and checked vacuum hose.
Also i have a multimeter with no dwell is there anyway to test ecm
components without dwell.
I would greatly appreciate all suggestions
Please read this first.
Thanks
http://www.car-forums.com/talk/showthread.php?t=2200
84 olds cutlass supreme 307 87,000 miles
What model and year is the Olds?
replaced ign. mod., but still same symptoms. 84 cut sup
Ever replaced the oxygen sensors? It is recommended they be replaced every 30,000 miles. :2cents:
going out to try 02 sensor now. any other suggestions greatly appreciated
Has the carburator ever been overhauled or replaced with a rebuilt one?
