351 Cleveland 4V CJ Rebuild
Home  \  Repairs & Maintenance  \  351 Cleveland 4V CJ Rebuild
Hey People!!
Maybe you, VWHobo, can help ?
This Wednesday (two days from now) I am getting my 351CJ rebuilt.
I went to many shops in town, and the one I've chosen was very professional, clean, and knew what they're talking about. Except one gripe:
I am confused as my shop suggests getting a 750cfm carb for the cam and manifold combo I am using. I will be changing to 3.55 gears soon, and my wheels are 15" with a 255/60 tire. IMHO I think 750 is too huge!! But my cam is huge and I have the exhaust to run such a high cam (true dual 2.5" w/H pipe)
Here is the specs of my cam... As you can see, its a dual grind camshaft by the different lift specs.
COMP CAM DUAL ENERGY 275DEH
RPM Range: 2000-6000
Advertised Intake: 275
Advertised Exhaust: 285
@ .050" Intake: 219
@ .050" Exhaust: 232
Valve Lift Intake: .515
Valve Lift Exhaust: .541
* works with mild converter
My manifold specs:
EDELBROCK PERFORMER 4V (Idle -5500rpm)
My carb shop wants me to get:
750cfm 4bbl Edelbrock Performer
square flange, electric choke
QUESTIONS
1) Would I have to change my torque converter to a stall of 2000rpm?
2) Is 750cfm too big?
3) Will the combos listed above work?
4) How much gross hp can I expect?
Thanks in advance people!!!!
Darryl
Canada
posted by  72Torino
Anyone?
posted by  72Torino
Testy,Testy.Remember,there are few folks left that know what an OHV Ford is :cussing: Let alone setup on an performance overhaul.
First off,a 351C 4V is not big on torque,and you are adding a pretty big cam.Think loose convertor,possibly in the 3000 RPM range.Thats alot of cam for a land yacht.Expect the need for a vacuum can if stoping is high in your list.
351C's are known as a decent revver,so a 750 sounds close.I might try something a little bigger.
Power?Tuned right,expect 375-400 ponies.
posted by  TurtlePimp
Noone will want to help you after that attitude.
I would be glad to help - unfortunately, I am not familiar enough with the 351-Cleveland or Modified Cleveland to give any suggestions or much advice.
Turtlepimp thanks for the info. :mrgreen:
TBaxleyjr thanks anyways :smoke:
DodgeRida67 that was an extreme waste of a post.
posted by  72Torino
72Torino,
How did your rebuild turn out? I am thinking of using the same cam on my 251C-4V (10.6:1) with an Offenhauser Intake (5964: Intake Manifold, 360 Degree, Split Single Plane, Square Bore, 351C 4V) and a 750 cfm Holley carb. Was the cam too big? What did you end up with and how does it perform?
Thanks,
Ian
posted by  69Stang
