1993 Buick Regal ECM programing
Hi All,
My 1993 Buick regal (3.8L) runs hot, especialy in the summer, after asking
some experts, they told me that the ECM is programed to activate the
cooling fan @ 210F. Any chance to change this setting or to re-program
these values in the ECM?
Sorry if I forgot anything else, I am newbie to the form.
Thanks in advance,
Raye.
Yes. You forgot to introduce yourself in the first forum listed on the
forum index page.
No, you cannot change it.
Even if you could, you would not want to do this. If your car is running
hot during highway driving (over 40MPH) then running the fan does no good
because at this time the air blowing over the engine from traveling down
the road takes over the job of the fan. The fan is only to help cool the
car when stopped or at low speeds and above tempuratures above 210*F. What
I mean by this is, your fan wouldn't help. Although, it's possible it would
help some, but you would partly be covering up the real problem which
should be addressed and not comprimized.
{quote= You forgot to introduce yourself in the first forum listed on the
forum index page} <- sorry for that, done :)
When running on the highway, no overheating, when stopping in a trafic jam,
the car starts heating up, if I turn on the A/C it helps and the car cools
down since the fans or activated with the A/C.
I heard that this 210F trigger issue can be re-programed in the ECM, but I
couldnt find any SW supporting this ECM number.
The ECM in the regal 3.8 is programmed to turn on the cooling fan('s) if
one of these two items occur: The Ac turns on and if the coolant
temperature sensor says the engine is @ a certain temperature. To figure
out why the car is overheating @ idle we need to rule out a couple of
things
Is the water pump working? After the thermostat has a chance to open, grab
the upper radiator hose and see if you feel a surge or pressure. This
pressure should increase if the engine speed is increased. If there is no
surge or pressure (equivilent to 10-15 psi), water pump is suspect.
If water pump is OK, then we need to look @ the cooling fan, its relays and
associated controls (you will need to find a wiring diagram to do this)
Turn the AC on. The one or more fans should start if the AC is on.
If car is warm or hot @ at idle the fans should be on (and on high)
There are three fan relays Relay 1 energizes fan 1 upon completion of
ground through ECM. The control/pull in power comes from a 3A fan svs
fuse. Power from fan 1 is fed to fan 2 (probably for low speed operation)
through fan relay 3. If high speed operation is called for from fan 2, a
ground is completed through the ECM and relay 3 opens and grounds fan 1
directly causing it to operate at high speed and relay 2 closes providing
full voltage to fan 2. Control voltage is provided from the 15A ignition
fuse. The fans are powered from a 30A fan fuse
to trouble shoot, you will need to verify fan control circuits are
completed, make sure fan relays are OK, make sure fans are operational
(jump a 12 V source to the motor leads and see if the fan works) and check
the affected fuses.
I am not sure this particular ECM can be reflashed to do what you are
wanting -you need to fix the problem.
Okay, just to clarify:
1)The fans do turn on when I turn on the A/C - No fan motor problem.
2)The thermostat and the water pump are functioning well.
3)When the car @ Idle (or trafic jam), and the A/C is off, the temperature
reaches ~220F before the fans turn on.
I think 220F is high temperature, and I am looking for a way to reduce this
220F "ECM trigger".
As I recal, when I first bought the car, the fans would start @ around
180F~190F; but after cleaning the radiator, and engine service, this
problem started.
So any sugestion is apreciated.
Thanks
Raye
Man, I hope this doesn't sound to trivial or stupid. Have you checked the ratio of antifreeze and water after the clean,flush and refill. Little miss glycol can't work by herself. Just a thought :wink2:
May want to check the coolant temperature sensor.
May also want to make sure relay 2 is operating and via relay 3 allowing
the fans to go from slow speed to high speed operation
