car forums
98 Ford Windstar high RPM's
For full features; Go to 98 Ford Windstar high RPM's
When I start the van it immediately jumps up to 2500 RPM's and stays there. I changed out the TP sensor and it made no difference. I got 9 ohms on the IAC which is in range I think. The O2 sensors were replaced a couple of months ago. Those should be alright. There's no check engine light. Do not know where to go from here. posted by  keeponshinin
check for vacuum leaks, see if you hear idle air valve motor run when ignition is on. any codes? if so get them read and get back to me. posted by  carls47807
