For full features; Go to Heeeellllllpppppp!!!!!!!!
I have a 92 saturn sl single cam. when i try to start it it wants to start
but won't and the thing where the fuel sensor is fills with fuel. i was
already told if it was the fuel pump that that thing wouldn't fill up when
i try to start my car.
boobookittynca
what fuel sensor? what thing fills up? fuel pressure and fuel volume are
2 different things.
carls47807
I have no clue what a fuel sensor is -- You need to pull the trouble codes
and follow the diagnostics.
A common sense thing to do to help is to do a fuel pressure and volume test
and check for spark. - this will get you started down the right path
tbaxleyjr
If i were you I'd turn it over a little bit and then pull a spark plug. See
if it's clean or has oil or gas on it. This will let you know what's
getting into the motor.
DBain
