For full features; Go to stalls when hot 93 hyundai scoupe
My 93 Scoupe runs fine until Ive been driving about 1/2 hour then the
engine hesitates and eventually dies. It will re-start but has no power
even if I give full throttle.
I replaced the fuel filter,put fuel injector cleaner in gas tank cleaned
and re-gapped all plugs, checked timing. Fans seem to operate normally,
engine temp gauge never shows HOT. Actually gauge seems to run below the
normal level.
Mechanic checked the coil and all wiring and changed the thermostat. I can
not take it to the dealer as I live on an island in the Phipippines where
there are no dealers.
Any help would be appreciated
thetheway
get a shop manual and pull the codes.
tbaxleyjr
Could be a lot of things. Could be an ign module, could be a crack in the
distributor cap, or it could be an EGR valve. Like he said pull the codes,
and start from there.
DBain
