car forums
5 wire central locking wiring
For full features; Go to 5 wire central locking wiring
Good Day
Please can some one help? i have a central locking actuator that is faulty, i have purchased a new one but the wiring does not correspond?on the new one it has five wires black (earth) white (not sure?) brown (live) blue (?) & green! now on the one im replacing the wire colours areBlack ( must be earth i think?) blue (?) Brown ( again would think 12v?) light blue (?) & red ( agin im not sure if this is ment to be 12v)?? can anyone help? :banghead:
thanks :thumbs: posted by  Dazzadb
The blue and green are most likely your 12V supply. They don't use red/black because you reverse the polarity depending on whether you're driving the lock up or down.
The white, brown and black will be for the switching (ie, on the driver's door, when you manually unlock the door, the actuator senses this and unlocks the others).
Look up the Electus Distribution website and look for a pdf called powrlock.pdf
Hope this helps. I'd play around with a 12V plug-pack power supply to determine which is your motor +/- 12V to drive the old actuator. posted by  windsonian
