car forums
96 dodge avenger
For full features; Go to 96 dodge avenger
it is a 96 dodge avenger ES. I went to the mechanic shop after the transmission slips. Actually what is happening is that in the morning when i start the car, it doesn't go into the drive or reverse for sometime. But then when i paddle on the gas, then with a hiccup it goes into either reverse or Drive. then when i continue driving it, it changes gears with some hesistancy. but once the car is warmed up, the car rune just fine.
Could it be the transmission, it has around 177000 miles on it. I also tried putting the oil which is thick to stop the transmission slip. It used to work earlier but this time it of little help. I went to the mechanic and there was transmision code alongwith the misfires of cylinders.
I recently changed the 3 spark plugs by myself..i changed it because when ever i stopped at the stop sign..the car was vibrating a little bit and it loks like it is going to stop. But since i changed the spark plugs...the problem is reduced to a gr8 extent.
In last month or so i have driven it almost 1400 miles....w/o any problems....but now the transmission hiccupps are a lot....I haven't had the transmission service....could u suggest me something..or do i have to get a new transmission....please help me out on this
Thanks
Davinder posted by  davindersohi
have someone who knows what they are doing look @ the car and give you a proper diagnosis and cost for repair. posted by  tbaxleyjr
