car forums
Wheel Bearing Maybe.......
For full features; Go to Wheel Bearing Maybe.......
I own a 2004 hyundai accent, 4 door, auto with a/c. It has 78 000 km. When ever I make a left turn, I get a noise coming from the wheel. Sounds like metal on metal. When I am at a stop I get no noise making a turn left and right. I have not noticed any play in the steering, and no viberation. There is no noise traveling straight and none doing 60 km. Is this the wheel bearing??? I thought possibly that this could be a loose brake pad rubbing the rotor. Could that be possible or is wheel bearing more like it.
thanks for any advice posted by  sean_hawn19
If you hear the sound while turning left only, then id have to say front drivers side (n/a) wheel bearing
when turning right you don't hear it, because there is more weight on it keeping it quiet
that was the case as per my car anyway posted by  nighthawk
Jacked up the car and took another look. Turns out it was the backing plate rubbing against the rotor. Bend it back and no more noise. Don't know how all of a sudden it got bend. posted by  sean_hawn19
strange, but better than having to shell out over $100 posted by  nighthawk
That actually happened to me. After I installed new struts in my car, somewhere along the line I bent that dust cover in enough to rub the rotor. I have to say tho, judging by your description, I would've guessed wheel bearing as well. posted by  DBain
