Grand Cherokee, Tachometer to ZERO!
Ah I have put my car in the shop about 10 times for this one problem and it
wont be fixed! I am looking to see if anyone has heard of such a situation
and could give me some advice.
I have a '94 Jeep Grand Cherokee, Limited. The car is nice but the engine
is driving me insane.
The problem: *Occasionally* while driving, the tachometer will simply
drop to zero instantly, and I'm talking about while i'm on the interstate,
but in other situations as well. While it is at zero, the engine does not
make any "reving" noise either, so its not just the gauge going crazy.
Despite me giving it gas, the car just slows down more and more. After
this, either the engine will turn off completely, or it will pick back up
again and will be fine. Lately I have tried pumping it gas when it drops
to zero, and I think this improves the chances of it picking back up. I
recently had the fuel injector replaced, but the problem still occurs.
Thoughts?
It's always nice to introduce yourself before expecting help...there's a section dedicated to it here too! :banghead:
Sounds like a bad ignition coil.
Sorry about the lack of an introduction. I dont know too much about cars,
so I wouldn't have much to contribute. Its just I have had this problem
with my car for a while now and I cant get any help with it, and I've tried
to look online but thats no help raelly either. I decided I needed to talk
to some people and I came across this board.
But about the ignition coil, obviously I do not know much about this, but
would that affect the performance of the car while its already running?
Ignition coil would ONLY affect it while starting and running. It don't do
much when the car's switched off.
Problem is when you buy electronic parts they are non returnable. Take the
coil off and to Autozone or Advance and have them test it. Chances are good
that if it's the problem it'll show up off spec in a diagnostic.
I don't see the link with the coil being faulty and the tach going to 0.
You may have a loss of electical power somewhere. Peek around for a loose
or corroded electrical connection.
the tacho is probably takeing its signal from the spark plug lead> The sparks go AWOL so the tach goes off too... i say Ignition problem. Coil/or the whole electronics.. maybe a Computer diagnostic would pick it up but sometimes these intemitant faults are just a question of subsitution till its fixed.
You mean they don't use spinning magnets on the end of cables any more??
:laughing:
Note to self: "Please engage brain before operating keyboard!"
not in the 21st century!...its all flying cars and silver foil suit now you know..
Alright,
I'm brand new to this forum. Actually registered to answer this post, but
I believe I may have this one pegged. I have a 94 Grand Cherokee Laredo,
which had very, VERY similar problems. It would stall out at highway
speeds, it would stall out at stopsigns/lights, it would stall out when I
was on a date. Basically, the car had a deep seeded hate for me, and went
out of its' way to inconvenience me. Sometimes it would crank right back
up, sometimes it wouldn't start again for 20 minutes. Often times, it
would stall on the highway, I could just throw it in neutral and crank it
right back up. And oh yes, the mechanics were all at a total loss. And
THIS is why I take my car to no one other than myself these days.
Crankshaft Position Sensor, my friend. Your problem seems very similar
to the one I had. Essentially, when the CPS begins to act up, this
happens:
The CPS monitors RPM's from the engine, sending this to the computer and
to your tachometer. When the CPS fails, it sends no signal to the
computer, telling the car that the engine is off (your tachometer as well).
Well, at this point, the engine will shut itself off, since it believes it
is not supposed to be on. Yes, sometimes you can catch it by rev'ing the
engine, but this is just throwing the car into high enough rpm's that it is
still cycling when the CPS comes back around. It is a problem that will
haunt you for months before it absolutely screws you at the worst time
possible. Anyway, It's a very simple fix. Go to your local parts store,
pick up a CPS for around $40. The CPS is mounted on the bellhousing of the
transmission, right at the back of the engine. Crawl under your car,
simply unscrew the existing CPS, pull it out, drop the new one in and
fasten it. Now, follow the wire of the old CPS up through the back of the
engine along the firewall, and plug the new connector to where the old CPS
was connected. I do hope this helps, and I feel fairly certain that it
will. Enjoy,
-Donk
let us know what you find
Yeah, I didn't word that correctly. The tach on those cars gets the rpm
reading through the computer, which is why it drops so abruptly when the
CPS acts up. Obviously the engine still is cycling, but it gets a signal,
or really the lack of any signal to give the 0 readout.
-Donk
lets see the rouble codes
When I had the codes pulled from my car, it didn't actually show the CPS as a problem. However, it did have a record of how many times the car had just shut down (like 64 times), and it informed me that my #4 injector was having problems. Fortunately, a friend of mine knew the CPS units were notoriously problematic on those cars, and the symptoms matched. It fixed it right up for me.
