car forums
Axle/CV Joint Problems? Don't Know... U tell Me!
For full features; Go to Axle/CV Joint Problems? Don't Know... U tell Me!
My 99 pontiac Sunfire has now been making clunking noises when cornering, mostly when I turn left, and it only happens when I turn. If I am not moving and in neutral and turn the wheel it does not clunk. It is not the wheel bearings, because I recently replaced both. All the boots on the axle are NOT torn, in which I was thinking it was the CV joints, but can a CV joint go bad and not have a torn boot? Any suggestions? I would rather fix it than have it crap out on me while doing 60+ down the highway... posted by  caioneach9
CV Joint. No doubt. It is very possible for the joints themselves to go bad and still have the intact boots. posted by  Satty101
Check your engine mounts for shear or cracking, before pulling wheels off and driveshafts out posted by  Wally
Damn, good point. I agree with wally. Check the mounts first.
Thanks for bringing this up Wally!:thumbs: posted by  Satty101
What would motor mounts have to do w/ cv's going bad?
I'm not insulting your knowledge... I just have absolutely NO experience with drive/suspension repair and diagnosis. posted by  caioneach9
The constant velocity joints are just one part of the drive shaft. The CV will knock when worn, but they will also knock if the transaxle is able to flay around. The transaxle is bolted to the engine. With poor mounts you can also get a situation where the driveshaft will seperate from the transaxle and clap back in.
It's much easier to give the mounts a test with a pry bar than going the full assault on the driveshafts. If you do change the shafts, make sure you drain the transaxle first. posted by  Wally
why drain the fluid? also, how do you test for bad motor mounts other than just looking at them? I know major engine movement is a noticeable one, but you were saying something about using a pry bar?
also when I put my car in park, it sounds like something is grinding, which I thought minor, could it be something to do with motor mounts going bad? cv joints/half shafts going bad?
the steering was feeling way too weird for normal operation so I just decided to park it until I get it fixed! driving my gf's 04 Saturn Ion now, for time being... I don't think there's one piece of metal on the body!
p.s.- u guys sure seem to know what your talking about tho... all advice appreciated! posted by  caioneach9
Slogan T-shirts from $15
itself Slogan T-shirts
SELL YOUR CAR
@ CF Classifieds
