For full features; Go to 84 Cutlass Supreme Engine sputtering...Choke Issue?
Hey,
I have an 84 Cutlass Supreme(as the title suggests), My car was sitting
around not being used all winter, and i just recently got it back on the
road. Now when i am between speeds of about 60-70kpm the engine sputters,
or hesitates. It goes away if I speed up, or slow down.
Something that could be related is that i do have trouble sometimes
starting my car. I have been told by a repair shop that i may have a choke
problem(that it sticks), but i have no clue.
Any help would be appreciated as i do not know too much about
cars(obviously, or i wouldn't be asking).
Thanks.
Craigt
The could be your problem could be the choke, but I suspect it is the carb
in general that needs to be adjusted or rebuilt or a few vacuum leaks. The
best thing to do is slowly repair the problems you know are wrong, then
move to the next likely causes and continue on this path until the problem
is solved.
So you know the choke sticks, so get it fixed and insure that there are no
vacuum leaks. Then move to the next likely causes, have the engine
tuned-up. Start with getting the timing set and proper adjustment to the
carb. Then maybe change the plugs, wires, cap and rotor. If you continue to
have the problem you made need to go deeper into the carb: rebuild or
replace.
I guess the main question to ask... is this a problem you would like to
tackle yourself? or are you just wanting to walk into the repair shop
informed so that you do not walk out paying for alot of work that you did
not need?
corbett_auto
